Author Topic: Mutron Flanger Clone  (Read 44219 times)
Govmnt_Lacky
Re: Mutron Flanger Clone
« Reply #20 on: November 15, 2013, 09:01:42 AM »
WOW!!!  :icon_eek:  :icon_eek:  :icon_eek:
Blown away Larry. Thank you so very much for all of the hard work!
Cant wait to get this going. Gotta find some FR4 big enough now  :icon_lol:
for an amount of up to and including my life.
digi2t
  • Total likes: 1659
  • "Digital? Any idiot can count to 1!" - Bob Widlar
« Reply #21 on: November 15, 2013, 09:50:31 AM »
Outstanding piece of work Larry. Truly humbling.
It was an absolute treat to work with you on this baby. A collaboration worthy of the Ludwig Award.  :icon_lol:
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
« Reply #22 on: November 15, 2013, 10:53:00 AM »
Larry is an absolute wolverine when it comes to involved projects, ain't he?  Once he sinks his teeth into it, he doesn't let go until it's DONE!  :icon_biggrin:
The ECG1641 is an MN3007 substitute, right, not a 3207 sub?  If I'm right, and despite the fact that I have too damn many flangers already, I may have to give this one a crack.  I am willing to sacrifice my Morley power wah for the cause.  :icon_mrgreen:
armdnrdy
« Reply #23 on: November 15, 2013, 11:51:18 AM »
I used MG Chemicals 512 (6" X 9" 1/16" FR4) for the prototype.
Mouser stocks it at a reasonable price.
I included it with my order of:
Piher trimmers
1.5f tant
10f bipolar elects
330Ω 1/2 watt resistor
Except for the long pin pots, (Mammoth or Small Bear) You should be able to find everything else at Tayda.
armdnrdy
« Reply #24 on: November 15, 2013, 11:58:58 AM »
Correct
Shouldn't you finish your Hyperflange build first?  :icon_wink:
I have a bit of a build backlog going now but.....I've been working with the ADA STD-1 factory docs as well as some Tycobrahe Pedal Flanger material.
We'll see what comes of it.
« Last Edit: November 15, 2013, 12:14:38 PM by armdnrdy »
« Reply #25 on: November 15, 2013, 12:28:54 PM »
Correct
  :icon_rolleyes:It's precisely these sort of distractions that have impeded me from completing the Hyperflange for 20 years.
armdnrdy
« Reply #26 on: November 15, 2013, 06:47:12 PM »
For further information:
Mutron Flanger Dissection thread here: http://www.diystompboxes.com/smfforum/index.php?topic=103542.0
Pedal Voltage control circuit discussion here: http://www.diystompboxes.com/smfforum/index.php?topic=103879.0
Bias voltage connected to In/Out jacks here: http://www.diystompboxes.com/smfforum/index.php?topic=104370.0
« Last Edit: November 15, 2013, 06:54:29 PM by armdnrdy »
« Reply #27 on: November 16, 2013, 10:31:46 AM »
Not to be picky, but the first op-amp stage in the build document shows a 390k feedback resistor and a .047uf feedback cap.  Should that be 47pf, rather than nf?
armdnrdy
« Reply #28 on: November 16, 2013, 12:06:39 PM »
Hey Mark,
Please be picky! If anything was missed, I would like to correct it.
The cap you are referring to is C3 right?
The factory schematic lists it as a .047f....but that can't be completely trusted.
Dino verified all of the component values.....but he can't be completely trusted either!  ;D
I also verified what I could see in images from the net and that Dino provided.
I used this info to make a component designation overlay as well as a component value overlay.
I used this to verify the schematic.
I couldn't make out most of the caps from the images, but with a little "electronics archeology" I can tell if the size looks in the ballpark for the value listed.
This is an image of C1 and C3, both listed as .047f.
Now.....time for me to learn. Why do the 390K and .047f values look suspect?
« Last Edit: November 16, 2013, 12:24:20 PM by armdnrdy »
« Reply #29 on: November 16, 2013, 02:56:01 PM »
I'm assuming - perhaps naively - that the feedback components ought to conform to the usual formula of F = 1/(2pi x R x C).  With a 390k resistor, that would make the high-end rolloff begin around 8.6hz.   Juuuuuuuusssstttt a little low.  If C3 were 47pf, that would be 8.6khz, which isn't hi-fi, by any stretch, but reasonable bandwidth for a guitar.
Is there something that *I* don't understand about feedback caps in unity-gain non-inverting op-amps?
armdnrdy
« Reply #30 on: November 16, 2013, 03:40:21 PM »
I just looked through folders of schematics for flangers and delays.
I see what you mean...I couldn't find any similar examples.
I think that the answer is in here somewhere.
http://www.physics.unlv.edu/~bill/PHYS483/op_amp_filt.pdf
Govmnt_Lacky
« Reply #31 on: November 18, 2013, 09:39:40 AM »
@Larry,
Any chance you could post some good gut shots of your build? Just so that us interested folks  8) can get an idea of the form/fit/function of the build.
Thanks!!
EDIT: Larry.... looking at the PCB layout. It appears that RX8 is connected to 2 traces. If you look near the "P" in Pedal Flanger 3007, when the layout is printed to size, the PCB pad for RX8 in this area connects to TWO traces. Is this correct?
« Last Edit: November 18, 2013, 10:01:51 AM by Govmnt_Lacky »
armdnrdy
« Reply #32 on: November 18, 2013, 11:51:18 AM »
Uhh.....yeah it looks like RX8 connects to two traces because it does!!.......but it's not supposed to!
Good catch Greg!
Here is the revised main board file with that fixed.
https://dl.dropboxusercontent.com/u/53299166/DIYstompboxes/Pedal%20Flanger%20main%20board%20.pdf
« Last Edit: November 18, 2013, 12:39:08 PM by armdnrdy »
Govmnt_Lacky
« Reply #33 on: November 18, 2013, 12:47:25 PM »
Thanks for the fix Larry!  ;)
Any chance of some pic uploads/gut shots? It is always good to see how the working unit was assembled  ;D
GodSaveMetal
  • Great Contributor!
  • Total likes: 4
  • Roberto Barrios Thays Lima -Per
« Reply #34 on: November 18, 2013, 01:25:48 PM »
Thanks to fix it!! great EAGLE look, thanks!!!!!!!!!!!!!!!!
armdnrdy
« Reply #35 on: November 18, 2013, 05:53:40 PM »
Here are some images. There really isn't much to see that isn't detailed in the build document.
When viewed from the bottom, with the bottom cover removed, the LED/LDR board is oriented component side up.
The main board is oriented trace side up.
The controls which are mounted to the main board component side are "upside down" and exit through the top of the enclosure.
The LEDs which are mounted on the trace side of the LED/LDR board are "upside down" and exit through the top of the enclosure.
Govmnt_Lacky
« Reply #36 on: November 18, 2013, 08:44:59 PM »
Thanks again Larry. Exactly what I was looking for and more!  8)
armdnrdy
« Reply #37 on: November 18, 2013, 09:32:14 PM »
One of these days I'll have to take this all apart, strip the powder coating off of the enclosure, paint it, and put the artwork decal on all proper like and stuff.  :icon_wink:
There are just too many projects!
digi2t
  • Total likes: 1659
« Reply #38 on: November 18, 2013, 09:57:31 PM »
Nooooooo..... leave it as is, and blow some minds when you step on it. I can hear the head scratching now.
That's why I don't dress my pedals anymore. Just leave them in a cloud of "What the hell was THAT?!"
Better yet, label it "Morley Pedal Flanger", and really mess with their minds. :icon_mrgreen:
Dead End FX
armdnrdy
« Reply #39 on: November 19, 2013, 11:04:40 AM »
To keep everything together all orderly....I reworked the original Build Document posted on reply 19 to include the revised main board PCB print. (small mistake corrected)
Flangerland is safe again from non working PCBs.  ;D
« Last Edit: November 19, 2013, 12:26:32 PM by armdnrdy »
