CHASM REVERB
Started by deadastronaut, November 20, 2013, 12:50:02 PM
Jdansti
Will.mendil
Might have been answered. But what are the two black components. Rectangle one with numbers backward and the other one with nothing on it up right and bottom left hand corners?
Don't know what to do with a paritculare transistor? Check this website where stompbox pedals are listed by what transistors they use
http://scfxguide.wordpress.com/
mth5044
Those are little patches of copper when the PCB is made.
Or at least I assume they are, as one has some text in it.
Circusbrains
They are nothing but good spots for standoffs; I only used one since the brick worked as one for me
icecycle66
Does anybody have the build doc for the fabbed board?
Jdansti
stallik
Finally had the time to complete this and I'm really pleased with the sound. No build issues apart from a jack socket shorting on a pot. Loadsa wires so hit them under the board. Finding a difference in the tails depending on the OSC setting. On bypass with OSC off, the tails linger until I mute the strings or hit another note on that string. With OSC on, the tails linger over the new notes of that makes sense.
Rob, if this was by design then my hat off to you. If I've made a mistake somewhere, I'm not changing it as it's really effective :icon_biggrin:
Am finding that on short, muted staccato notes, the delay repeats are very obvious though that's disguised during normal  playing. Using a long delay brick, wondering if a short one would help
Guts
haveyouseenhim
WOW. That's great.
How did mine turn out looking like a spilled bowl of spaghetti? No one else seems to have a problem with getting the wiring neat.
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
stallik
Thanks Mike. Trust me, if you saw under the board... Bit of a rats nest held in place with a loose cable tie. Just had to leave enough length on the wires to allow the board to be lifted if necessary.
Jdansti
Beautifully done, Kevin!
+1.  Really nice job, Kevin.  And cool that you included Rob on the front, too.   :icon_cool:
Mine is still at the completely-unbuilt stage.  I'm concerned that mine will be nowhere as neat, with all that wiring to do (great concealment, btw!).  More likely to be like Mike's spaghetti, or worse... some kind of alien autopsy...   :o
haveyouseenhim
Quote from: bluebunny on April 15, 2014, 03:19:19 AM
Or worse.... A spaghetti autopsy. :icon_eek:
nice one kevin, looks great, and really tidy too...
no that wasn't a deliberate design btw, but if it works for you then even better.. ;D call it a 'feature'  ;D
cool.
btw guys i should be  getting boards fabbed pretty soon. for onboard pots , brick, switch ....no more spaghetti. ::)
as soon as they are available i will test build and post up ok. ;)
therealfindo
Quote from: deadastronaut on April 15, 2014, 05:11:58 PM
ah.. in that case...
I was bracing myself to try and fit it on a 125B sized board!
just waiting on postman.. ;)
haveyouseenhim
Quote from: deadastronaut on April 29, 2014, 05:25:24 AM
Eeeeek!  I can't wait. I'm ready for another.   Can we get a teaser?
therealfindo
1590bb
heres a teaser: ;D
onboard brick, pots, switch...
in the uk its impossible to get onboard pots, so i will be wiring mine anyway... ::)
therealfindo
Quote from: deadastronaut on April 29, 2014, 05:44:27 AM
1590bb
heres a teaser: ;D
well.. maybe I'll stick with my ambition to stick it in a smaller box then ;)
oh and onboard brick...neato!.
