MXR Noise Gate Tonepad Revisited Need Help
Started by Zipporello, November 22, 2013, 08:52:58 AM
2n5485 should be a primo device for this circuit. when you say "doesn't have a gating", do you mean it won't mute or won't open? have you made any other subs?
can you measure some voltages? we need the no signal dc voltage at the 150k//1uF//transistor collector, and the voltage at the gate of the fet. then give the same voltages (they should rise and fall slowly, we want both extremes measured) when you give a wang on yr axe.
if you can get the unit to gate and ungate at any setting, can we have the voltages for that, please.
aswang05
What I mean to say is that when I set the grunge and level to the 12 o 'clock position, it just seems like i have no MXR noise gate at all. but when the grunge and output control is in 9 o 'clock, it just works out fine
the 12 o'clocks will mean more signal and more noise. you should be able to reduce the sensitivity on the mxr to compensate.
aswang05
Thanks..... ;) I'll get back to my working table then. thnx bro
MrStab
my issue when i first built this circuit was that i didn't really consider how the noise floor is so sudden - your issue kinda reminds me of that, Aswang. maybe you could test with several noisy pedals with different settings and see how they interact with the Threshold/Sensitivity control. Attenuation should always be max for testing, imo - in fact, i omitted it completely from my 2nd build.
Recovered guitar player.
Electronics manufacturer.
