Author Topic: 13700 Noisegate/Expander  (Read 44257 times)
disabled_shredder
Re: 13700 Noisegate/Expander
« Reply #100 on: March 28, 2014, 11:59:05 PM »
Hey so I have built the gate only using a 1k for r27 the status led and a tl071 and 2n5088/87 in place of stock transistors q1 is getting to hot to touch I am getting no effected signal but I am getting signal in bypass mode! I do not know what the voltages should be but will measure them and post. Also there are absolutely no solder joints I have checks dozens of times. Does anyone have any idea?
The wild man with a loaded gun and no plan. I'm not held back by rules, just don't know which ones to follow
armdnrdy
« Reply #101 on: March 29, 2014, 01:18:49 AM »
You did check the pin out of the 5088/87 right?
They should be facing the opposite way than the BC550s are depicted on the layout.
VahiD
« Reply #102 on: April 20, 2015, 12:47:55 PM »
hi , how can change the decay ? i want faster decay plz help
« Reply #103 on: April 20, 2015, 06:46:05 PM »
It's going to be either R22 or R17.  I don't know which.
VahiD
« Reply #104 on: April 21, 2015, 04:12:50 AM »
tnx its r17
lower resistor = faster decay
VahiD
« Reply #105 on: April 21, 2015, 10:41:24 AM »
what about other mods ? can anyone help ?
« Last Edit: April 22, 2015, 08:27:01 AM by VahiD »
VahiD
« Reply #106 on: April 22, 2015, 02:08:26 PM »
why my clean signal change a bit with this pedal ? i have a bit of noise or gain or someting like this in my clean signal and TR1 is not working plz help tnx
« Last Edit: April 22, 2015, 02:10:48 PM by VahiD »
VahiD
« Reply #107 on: May 12, 2015, 09:08:06 AM »
nobody can tell me why my signal is change ? if you can plz help me
Tnx all
POTL
« Reply #108 on: September 06, 2017, 06:09:20 PM »
Hello I came across this project on madbean's website
Someone compared this loudspeaker with ISP Decimator
Or is there nothing better ISP?
armdnrdy
« Reply #109 on: March 24, 2018, 04:06:28 PM »
I received a private message for the project file link that was deleted by dropbox.
As requested:
https://www.dropbox.com/s/9eej1fsdldfs7ct/Noise%20Gate%20-%20Expander%20build%20PDF.pdf?dl=0
« Reply #110 on: June 02, 2018, 05:02:15 PM »
Anybody have an idea how to add attack pot to this gate?
50 pedals and counting!
