What to do with a Hole Punch???
Started by mac, March 04, 2014, 09:45:38 PM
mac
A Colorsound Inductorless Wah (CIW)!!!  ;D
Pot is 250kB, range about 30k, enough for this circuit or similar ones.
Metal is from a zinc sheet.
As the angle is less than 45° a 250k to 500k pot must be used. A parallel resistor can be used to find the best range.
Screeching noise is optional!
mac
GibsonGM
It sounds sharp, but not quite as icepick-to-the-forehead as I would expect - do you think you need add a buffer??    ;o)
mac
samhay
can it be adapted to pump crude oil?
mac
that's a good idea!
pumping oil that can be used to get rid of the noise!
mac
it's not so much inductorless as it is totally wah-less.
mmlee
italianguy63
mac
Quoteit's not so much inductorless as it is totally wah-less.
QuoteHave you ran a sim yet?
I ran simulations, and I found a couple of mods that makes the peaks almost of the same height.
http://www.diystompboxes.com/smfforum/index.php?topic=99448.0
mac
