Author Topic: X FUZZ  (Read 147958 times)
Domin
Re: X FUZZ
« Reply #420 on: August 23, 2020, 06:23:29 AM »
Somehow PCB is working and sound is sweet, but bias is homehow weird but ill let it be how it is :) Its pity I cant send audio
Re: X FUZZ
« Reply #421 on: August 23, 2020, 06:24:37 AM »
excellent'e.... 8)
Domin
Re: X FUZZ
« Reply #422 on: August 23, 2020, 06:30:17 AM »
Thanks a lot :)
Re: X FUZZ
« Reply #423 on: August 23, 2020, 06:35:12 AM »
your welcome, enjoy.... 8)
11-90-an
Re: X FUZZ
« Reply #424 on: August 23, 2020, 06:44:00 AM »
you *can* send audio by recording it and putting it in youtube, soundcloud or other sites, then type in the link here... :icon_wink:
flip flop flip flop flip
Re: X FUZZ
« Reply #425 on: August 23, 2020, 06:47:18 AM »
^ yup this... 8)
Domin
Re: X FUZZ
« Reply #426 on: August 23, 2020, 07:17:23 AM »
Ok, if I record something decent (I dont have amp right now, so I recorded just thru Vox Amplug and putting headphones next to mic of my phone), I'll send it :)
Re: X FUZZ
« Reply #427 on: August 23, 2020, 07:25:25 AM »
if you need a good little amp that takes pedals well , search ''punch amp'' or ''chime amp''
your next build...  ;)
http://guitar-fx-layouts.42897.x6.nabble.com/Chime-Amp-Punch-Amp-v-2-td8493.html
Domin
Re: X FUZZ
« Reply #428 on: August 23, 2020, 08:05:32 AM »
I have amp, but 20W Ampeg :D And now I dont have it nearby, and I have bass, so Punch amp or Chime amp wont work so well I think :) Only if I plug 10" speaker into it :D But thanks for a tip :)
Re: X FUZZ
« Reply #429 on: August 23, 2020, 08:07:33 AM »
ahh gotya..thought you didnt have an amp at all... ;)
Domin
Re: X FUZZ
« Reply #430 on: August 23, 2020, 08:26:30 AM »
Its good that Ampeg and I have that Vox Amplug Bass 2, but I'm thinking about some tube preamp running on 9V...
Domin
Re: X FUZZ
« Reply #431 on: August 24, 2020, 11:51:26 AM »
Its boxed, just in plastic box, but should be ok :) And I didnt use true bypass but this style of switching, but with DPDT switch and Im switching battery with it too...
Domin
Re: X FUZZ
« Reply #432 on: August 24, 2020, 01:31:35 PM »
Is normal that diodes are glowing when I turn it on?
Theres schematic how its connected...
It happens only when I turn pot to one side
« Last Edit: August 24, 2020, 01:46:38 PM by Domin »
Re: X FUZZ
« Reply #433 on: August 24, 2020, 02:16:43 PM »
A couple of things...
1. I wouldn't really expect to see much light from the LEDs - certainly not as bright as your picture shows.  For them both to be lit at the same time suggests one is round the wrong way.
2. Switching power with the bypass stomp-switch is not a good idea.  Particularly in the middle of a song.
3. A plastic box means you'll pick up radio stations, microwaves and WiFi.
4. Your switching scheme means the circuit is constantly sucking at your guitar signal.
If you can't get hold of a 3PDT switch, check out R.G.'s Millennium switching system (at the GeoFEX link above).  And use one of the common schemes for wiring jacks and batteries so that power is switched on when you insert your guitar lead.  I use the ones at Tonepad all the time.
Domin
Re: X FUZZ
« Reply #434 on: August 24, 2020, 02:23:20 PM »
And if I just use DPDT as a true bypass and separate switch for battery?
Domin
Re: X FUZZ
« Reply #435 on: August 24, 2020, 03:30:17 PM »
I made it with 2 switches and same problem, but I dont know if LEDs are lightning up when I turn up wolume or turn down
« Last Edit: August 24, 2020, 03:33:47 PM by Domin »
Re: X FUZZ
« Reply #436 on: August 24, 2020, 05:21:43 PM »
Use a stereo input jack and wire the black battery lead to the ring lug.  With no guitar lead inserted, it's not connected to anything and the battery doesn't drain.  Put the (mono) guitar lead in, and the ring and sleeve lugs are shorted by the plug, thereby connecting the battery -ve to ground and completing the circuit.
Domin
Re: X FUZZ
« Reply #437 on: August 25, 2020, 01:55:39 AM »
I dont have stereo jack :( Isnt using switch same thing? Look at this video and you'll see what is problem
https://youtu.be/Ql0u2E7ZG2A
When I turn battery on, its ok, when I touch pot with finger they light up, but when I touch battery they dont light...
deadmandance
Re: X FUZZ
« Reply #438 on: September 02, 2020, 12:27:13 PM »
Does anyone have a vero layout for this version? Wanted to give it a try, but I only got stripboard with me
Here's my corrected layout:
Domin
Re: X FUZZ
« Reply #439 on: October 10, 2020, 08:37:58 AM »
Can somebody tell me opinion to this? I want to put it as a onboard effect...Its like boost/fuzz, with switch I can sellect between first stage or second stage of 2 transistor XFuzz...
