Author Topic: X FUZZ  (Read 132937 times)
Re: X FUZZ
« Reply #60 on: April 14, 2014, 03:43:00 AM »
I think,the pot is forming a filter with your C2 which is why it is rolling off some high end.
yeah that makes sense now i look at it... (i'll take a look at that BMP with contour too, cheers bryan. 8)
@prr: oops yes...i shall remedy.  8)
Re: X FUZZ
« Reply #61 on: April 14, 2014, 06:39:10 AM »
ok, i give in  ;), i put the 1M gain pot across the collector and base of Q1...which works , and now it doesn't change the tone etc...great
however there is DC on it as its scratchy as hell...
@gus: added v for ya!.. ;)
Brymus
  • Total likes: 1
  • Bryan G. - Somewhere in the Mohave Desert USA
Re: X FUZZ
« Reply #62 on: April 14, 2014, 12:36:26 PM »
Now you need R1 again ,since you moved the pre gain pot.
I'm no EE or even a tech,just a monkey with a soldering iron that can read,and follow instructions. ;D
My now defunct band http://www.facebook.com/TheZedLeppelinExperience
Re: X FUZZ
« Reply #63 on: April 14, 2014, 01:46:03 PM »
oops oh yes... 8)
i tried a recovery stage on it today too, much better, (lifted from the big muff ( at least that came in useful lol. ;D.)
sounds cool still... 8)
samhay
Re: X FUZZ
« Reply #64 on: April 14, 2014, 03:56:02 PM »
As promised, I have this on the breadboard.
I think the LEDs should be oriented with cathode towards base. Once I figured this out, it wasn't noticeably gated and worked ok with the volume rolled back.
It is savage at max gain, but mostly in a good way. I added a base resistor to Q1 to tame it a little and make it play nice with others. It was squealing pretty badly on the breadboard without a buffer in front, so a small cap to ground here might help too.
I tried the 'Blues Breaker' style gain control with lug 3 of the gain pot connected to C4. At max gain, this is equivalent to how its drawn at the moment, but it lets you back the gain off a little easier.
You certainly need to roll of some fizz, and the SWTC does this nicely.
Re: X FUZZ
« Reply #65 on: April 15, 2014, 02:03:00 AM »
On what? The Gain pot?
The way you have it on #61, the "gain" really does violence to the DC conditions. (Meter the collector while you diddle "gain".) I suspect the C-B resistor should be fixed, and an input level pot put before the input capacitor (you may have done this before?). There's other ways but more complex.
Re: X FUZZ
« Reply #66 on: April 15, 2014, 09:38:05 AM »
@sam: ahh cool, you have it on bread too...
yep cathodes/anodes ...i'll sort that, :icon_redface:
the SWTC tames it a lot for the better for sure, non squeely... 8)
is your gain pot scratchy?.... i'll meter mine in a bit.
''violence to the DC conditions''  :)  i'll check for violence too.. ;D
edit:
@paul: whilst diddling the gain pot i get...0.63-2.54v..
edit:
sam, i put my gain pot the same as yours now, but still scratchy... :)
« Last Edit: April 15, 2014, 10:17:50 AM by deadastronaut »
DDD
Re: X FUZZ
« Reply #67 on: April 15, 2014, 10:40:36 AM »
Is the gain pot actually necessary here?
Guitar volume pot does srtrictly the same without any scratchy sounds and without extra components IMHO.
Too old to rock'n'roll, too young to die
Re: X FUZZ
« Reply #68 on: April 15, 2014, 10:46:14 AM »
@DDD:  its a nice option to have it just for slight breakup in an amp really....
Will.mendil
Re: X FUZZ
« Reply #69 on: April 15, 2014, 11:00:07 AM »
Since I started on solid stat amps I need really use the volume pot on my guitar which might be a shame but really preference the pedal to self contained. I only use the volume on the guitar to kill the humms and feedback a when I am not playing.
Don't know what to do with a paritculare transistor? Check this website where stompbox pedals are listed by what transistors they use
http://scfxguide.wordpress.com/
Re: X FUZZ
« Reply #70 on: April 15, 2014, 12:39:48 PM »
one other issue i found is the volume on guitar when lowered also rolls of the hi tone too (  on single coil neck pup)
the bridge hum pup fairs much better...
Will.mendil
Re: X FUZZ
« Reply #71 on: April 15, 2014, 02:27:48 PM »
I d like to go back to the x fuzz. I ve bread boarded it making sure it was exactly what you did and I don't get at all the sound you have on your YouTube video. What set up did you use? Do you have any further information ? Has anyone tested it ?
Will.mendil
Re: X FUZZ
« Reply #72 on: April 15, 2014, 02:28:06 PM »
I like the rock but I love your fuzz
Re: X FUZZ
« Reply #73 on: April 15, 2014, 02:51:07 PM »
the schemo on page 1 is what i used for the vid,,
i used yellow 5mm leds if that makes a difference.
try taking the 220k to base ...
« Last Edit: April 15, 2014, 02:53:27 PM by deadastronaut »
Will.mendil
Re: X FUZZ
« Reply #74 on: April 15, 2014, 03:13:54 PM »
obviously it had to be the only colour I cannot find :(.
What do you mean taking the 20K to base?
Will.mendil
Re: X FUZZ
« Reply #75 on: April 15, 2014, 03:15:55 PM »
I can only find 3mm yellow, they are 1.841V, what are yours?
Re: X FUZZ
« Reply #76 on: April 15, 2014, 03:18:04 PM »
try taking R5 220k to base of Q2 . instead of collector..(page 1 schemo)
not sure of 5mm yellow voltages...2.4v maybe..
Will.mendil
Re: X FUZZ
« Reply #77 on: April 15, 2014, 03:33:09 PM »
That's what I understood, but R5 is already on base, and collector, putting both legs of R5 to base do you mean?
I know that the yellow's voltage are between the green and red, and i tried both but it only does the x rock sound.
Has anyone else managed to get the same sound? I'm pretty clueless there :s
Re: X FUZZ
« Reply #78 on: April 15, 2014, 03:36:21 PM »
i mean take the 220k to base, and not to collector..
ok, give me a minute and i'll adjust my breadboard to the x fuzz and test again ok...
back in a bit..
Will.mendil
Re: X FUZZ
« Reply #79 on: April 15, 2014, 03:52:32 PM »
is that what you mean???? i am confuse.
thanks though
