Author Topic: X FUZZ  (Read 147907 times)
Re: X FUZZ
« Reply #200 on: May 28, 2014, 07:22:27 AM »
ahhhh thats you...i wondered who that was on my youtube ..hi darksid ;D
cool, sounds quite chunky ,
i was twiddling with my mixer settings and the Xrock and found it can get in the realms of heavy chunky riff stuff with the right eq...
my mixer has a nice mid section, 2 controls, mid and sweep...i'd like to nail that as an eq in a pedal for sure... :icon_twisted:
but for now i think i'll keep the xrock as is...i'm pretty happy with it. it must be, its been on the bread for months now... ::)
Darksid
Re: X FUZZ
« Reply #201 on: May 28, 2014, 07:42:53 AM »
Deadastronaut Hi, Yes I have just added a TON there prvda differently http://vk.com/vas67?z=photo176059711_326061425%2Fphotos176059711
« Last Edit: May 28, 2014, 07:52:46 AM by Darksid »
WhiskeyMadeMeDoIt
Re: X FUZZ
« Reply #202 on: May 28, 2014, 10:46:56 AM »
Alright Rob I replaced the 1uf Between the stages and put in the 470nf and I get synthy notes again when I dial the bias back. Hey! Cool.  Ok I'm still not completely satisfied with it but it's getting better.  Seems like there is less separation between the clipping types now.  Maybe I'm just fuzz blind after a/b testing for an hour.  I'm calling it quits for now and will fiddle more with fresh ears later.  If you get a chance try that second output stage I posted and see what you think.  It's is not the same and has its own character. Your mileage may vary ;)
haveyouseenhim
Re: X FUZZ
« Reply #203 on: May 29, 2014, 09:01:50 PM »
Would someone look this layout over and see if I made any mistakes?  Nevermind the component numbers vs the schematic. Just the values.
The gain is bottom left, tone is bottom right, the volume is top right, and the bias is the two pads just left of Q3
Re: X FUZZ
« Reply #204 on: May 29, 2014, 09:13:14 PM »
no 470k R6. ;)
haveyouseenhim
Re: X FUZZ
« Reply #205 on: May 29, 2014, 09:20:38 PM »
no 470k R6. ;)
Awesome. Is that all?  I was able to add a semi standing resistor to the layout. I can't update the post at the moment but I got it in there.
Re: X FUZZ
« Reply #206 on: May 29, 2014, 09:33:08 PM »
yep looks ok apart from that.. 8)
you might want to use  250k pot for bias.. ;) thats what i have on the vid. (my mistake.  ::))
« Last Edit: May 29, 2014, 09:35:04 PM by deadastronaut »
Darksid
Re: X FUZZ
« Reply #207 on: May 30, 2014, 05:40:42 AM »
haveiouseenhim and what happened transistor D3,?
WhiskeyMadeMeDoIt
Re: X FUZZ
« Reply #208 on: May 30, 2014, 06:13:37 AM »
Transistors are marked as Q and diodes are marked as D.  This is the new schematic it only has 2 diodes not 3 like the original.
Re: X FUZZ
« Reply #209 on: May 30, 2014, 06:25:14 AM »
yep, 3 leds were there just to  lift it, before i addded the recovery stage...
Re: X FUZZ
« Reply #210 on: May 30, 2014, 07:56:39 AM »
@mike: where is Q2's 10k?...R5..
haveyouseenhim
Re: X FUZZ
« Reply #211 on: May 30, 2014, 08:09:23 AM »
R4 on my layout.
Re: X FUZZ
« Reply #212 on: May 30, 2014, 08:16:28 AM »
ahh gotcha....need more coffee.  ;)
Darksid
Re: X FUZZ
« Reply #213 on: May 30, 2014, 08:38:05 AM »
Mike I have my layout I have done differently.
http://files.mail.ru/2ACDFD5C23484C7DBADDFC40CDBACE7E
Re: X FUZZ
« Reply #214 on: May 30, 2014, 11:25:29 AM »
спасибо :) она хорошо выглядит!
Do you have one with just the transfer?
WhiskeyMadeMeDoIt
Re: X FUZZ
« Reply #215 on: May 30, 2014, 11:28:39 AM »
Darksid that looks nice. Good job.  Post one without the components.
Mario44
Re: X FUZZ
« Reply #216 on: May 30, 2014, 12:13:47 PM »
Hey guys
I'm using 2n3904 transistors in xfuzz, but I can't obtain that cool synthy sound. Is it possible that it's transistors fault or I took wrong schem?
Took the blue one from page 6.
pappasmurfsharem
Re: X FUZZ
« Reply #217 on: May 30, 2014, 02:52:25 PM »
Hey guys
WHen I first breadboarded I tried 2n5089s instead of 5088s and it was really fuzzy so transistors might matter a bit. HfE values and all that jazz
"I want to build a delay, but I don't have the time."
Darksid
Re: X FUZZ
« Reply #218 on: May 31, 2014, 04:16:01 AM »
Instead try 2n5088 transistors KT3102Em with them works well too Tolko need them to turn 180 degrees to the other-pinout. http://my.mail.ru/inbox/20vasiliy/photo/_myphoto/151.html
« Last Edit: May 31, 2014, 04:32:59 AM by Darksid »
Mario44
Re: X FUZZ
« Reply #219 on: May 31, 2014, 11:43:46 AM »
What should be minimum hfe for this circuit?
The easiest transistors to get for me would be BC.
