Author Topic: TS-9 Clone (no sound)  (Read 4959 times)
gegadeath
« on: April 08, 2014, 12:44:42 PM »
Hi,
This is my very first post in this great forum. I decided to dive into diy projects and I was able to make my very first PCB using the toner transfer method. I managed to build a TS-9 clone (from Tonepad) everything looks good except for there is no sound. I desoldered the byapass switch and soldered the battery wires, input and output straight to the board to make sure the issue is not coming from offboard wiring. I noticed that when everything is plugged in when I unplug and replug the battery I can hear the effect sound but just for a couple seconds and then it shuts off again. What could be the cause of this annoying problem? Please help. Thank you !
Re: TS-9 Clone (no sound)
« Reply #1 on: April 09, 2014, 12:26:11 PM »
hello, and welcome to the forum, gega.
we always like to say, go here, follow instructions, come back and post results.
http://www.diystompboxes.com/smfforum/index.php?PHPSESSID=3c3f5593679a95b8263d69b1b295bc86&topic=29816.0
we also like to see pictures of your work, copper and component sides, and offboard wiring.
"I'm your vehicle, baby", but go easy on the clutch.
"You've got a suss sus sus sus sus sus sus suspect device."
