Author Topic: LM386 Bridged Distortion Pedal?  (Read 9264 times)
Alan410
« on: April 19, 2014, 05:51:32 AM »
Hiya!
I followed a schematic : http://www.runoffgroove.com/littlegemMK2.png
And ended up with a near satisfactory amplifier.
I brdiged the 10uf capacitors and replaced it with a 10k pot that adds distortion.
The problem is that when I connect my guitar, I get no audio at all. If I connect it to my computer I get sound.
Also there is alot of background noise.
I removed the JFET that was supposed to be there because I didn't have one, it still works without it, not sure what it was for in the first place.
My distortion is also a bit messed up, having the my pot off (lowest) and then turning it up lowers the sound, but then builds up to the highest volume.
So problems I have are:
No sound from guitar.
Bad/strange distortion
Bad quality sound
Re: LM386 Bridged Distortion Pedal?
« Reply #1 on: April 19, 2014, 01:42:25 PM »
Hiya!
Hiya!  Welcome...   :)
If you removed the JFET (it was a buffer), at what point do you introduce your signal?  Did you also lose the 1M5 resistor to ground?
Jdansti
« Reply #2 on: April 19, 2014, 01:58:13 PM »
The JFET is your preamp. I'm guessing that the signal from the guitar is too small for the rest of the circuit to work without it. Your computer's output is already amplified.
BTW-Welcome to the forum!
« Last Edit: April 19, 2014, 02:00:42 PM by Jdansti »
diydave
« Reply #3 on: April 20, 2014, 05:07:16 AM »
Change the fet-buffer to a fet-boost.
Really good distortion.
