Author Topic: OMG Fuzz Version 1  (Read 14883 times)
suryabeep
Re: OMG Fuzz Version 1
« Reply #20 on: August 27, 2017, 10:19:27 AM »
Aw man, this fuzz seems promising from the descriptions but all the picture are on photo bucket  so I can't see them [emoji20] could someone please repost them with a different image uploader? Also, Sound clips!
Still in the process of learning, so bear with me if I ask dumb questions :P
dv8r601
« Reply #21 on: August 27, 2017, 11:04:08 AM »
Just build OP'S Vero layout. I did and it blew me away. Or go to effectslayouts.blogspot.com and there is a perf layout and pcb layout. This is the most amazing fuzz ever
GGBB
« Reply #22 on: August 27, 2017, 01:24:43 PM »
I have a tampermonkey/greasemonkey script if you use one of those plugins in firefox or chrome: https://openuserjs.org/scripts/gtranter62/PhotoBucketImageReplacer. Set up to work only on diysb but you can easily change that. One trick is that after you click the photobucket link you need to reload (F5) or you will still see the upgrade image.
Plexi
« Reply #23 on: August 27, 2017, 01:41:03 PM »
Thats right!
David made an excelent work there
To you, buffered bypass sucks tone.
To me, it sucks my balls.
Cozybuilder
« Reply #24 on: August 27, 2017, 02:14:18 PM »
Another Photobucket casualty. I built a total of 4 of these, 3 in 1590A,s and 1 in a 1590LB. I sent the 1590A's to Michael to record, he still has them. The 1590LB is still one of my favorites.
Here are the docs for the as-built perf version. If I were to redo this, I would change the power scheme: instead of 1N4001, I would use a 1N5817 Schottky, followed by 47R in series, then 100uF electro and 100nF ceramic in parallel to ground.
Plexi
« Reply #25 on: August 27, 2017, 07:01:24 PM »
Cozy.. amazing job!
I hate the veroboards...but your work made me reconsider it
Cozybuilder
« Reply #26 on: August 27, 2017, 10:31:22 PM »
Thank you! Vero is not my favorite either, but enough people use it I thought it was worthwhile to do a layout, and of course had to build it to verify. Most of my builds are on plain perf, with occasional PCB builds.
Egon Juver
« Reply #27 on: February 14, 2018, 06:28:34 AM »
Hello, I'm from Brazil and I have a question: does the blue LED (first layout) work like a led flash or something like that, does it change the brightness (as if it blinks) how much do I play? If not, would there be any way to do it, then a led "blinking" in addition to the led on / off? I hope I have been able to explain my doubt ...  Thanks for any reply / info.reply / info.
« Reply #28 on: February 14, 2018, 08:22:37 AM »
Hello, Brazil, welcome to the forum.
the blue led - no, and maybe. it might flash sometimes, but it will be a disappointing effect. it is only meant to clip/bias the transistor, not provide visual display. there are some "sound to light" circuit things to find on this forum, tho, which might be the easiest way to do your thing.
pernickets cantankered here.
Egon Juver
« Reply #29 on: February 15, 2018, 05:52:28 AM »
Thanks duck_arse.
I'll try to find something here in the forum then.
dv8r601
« Reply #30 on: February 15, 2018, 03:20:27 PM »
I love this circuit. It can tell you when clipping is going on but a lower Vf LED is needed. I tried a pair of 3mm IR(infrared-Purple) LEDs and they start lighting up and flashing as soon as the gain is past 9 o clock. I have 2 holes drilled in tg3 enclosure for them and they are like the seeing eye mod keeley does on the Boss DS1. But that said the Vf of these is nearly half that of the blue LED the scheme calls for.
