electrip, would you mind taking a photo of your tester showing what the display looks like when testing a transistor? I think I may pay the extra bucks to get the one you got because it tests leakage. Also yours tests JFETs does it not? Much appreciated.
Well this sucks, apparently the new M328 firmware doesn't show leakage.
http://www.ebay.de/itm/Transistor-Tester-Diode-Triode-Capacitance-ESR-Meter-MOS-PNP-NPN-Module-Schale/271498772909?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D24201%26meid%3D8900038664636516450%26pid%3D100011%26prg%3D10287%26rk%3D1%26rkt%3D10%26sd%3D271556264712
Hi Ripdivot,
I've got the one from your ebay link, same seller, same tester.
M328 is the processor/controller type, firmware (functionality) is 1.10k on mine which is up to date.
Mine does measure JFETs but I don't like the data format I @ Vg.
I prefer the Vgs(off), gfs, Id and Vgs(on) data from my Peak DCA 55/75.
Leakage is only displayed if the tested transistor has some leakage
so most of silicon bjt will show only HFE and Uf data.
In my opinion it is a 'good to have' thing with its pros an cons.
I once zapped my PEAK LCR 40 and bought a new one (quite expensive)
but i wouldn't do it again because the MK-168 does it all for less money.
And it does diode_capacity, ESR and both poti-resistances at once.
Easy for a quick check of any part at your workbench.
The testers with bigger display will not measure more or better data it is just the presentation.
I was going for the one with the enclosure for practical reasons.
For serious research on specific semiconductors nothing beats the ATLAS PEAK DCA75 pro
with its curve tracer functions and data export to spreadsheet analysis (-> spice model).
And you can download updates from the manufacturer.
Hope this helps a little,
electrip
