Howdy!
Schematic:
Here is the schematic - veroboard for green citrus MKII.
http://guitar-fx-layouts.42897.x6.nabble.com/file/n10083/001-GreenCitrusMKII.png;cid=1405276443201-225
The question marks are for biasing the transistors correctly. I am using sockets for the transistors and the resistors while biasing.
Photoalbum of Build:Here is a photo-album of my build:
http://imgur.com/a/gmXJ3#0Deviations from Build:Did not install the LED on the board, nor the LED+ wire. Instead I used the following offboard wiring:
http://1.bp.blogspot.com/-k5Sh68yVU18/TzGRFKbiALI/AAAAAAAAAlk/CbfaaduUjYQ/s1600/%21Offboard+wiring.png
I also swapped the J201 for 2N5457 for Q3 and Q4 - would this make a huge difference?
The pedal is fine in bypass mode, but makes no sound when engaged. The light turns on correctly with the foot switch. I re-checked solder joints, measured my resistors as best I could without desoldering the whole thing, and checked the voltages on the leads on the power rail is 9v. What's curious to me is that with this design of the 3PDT offboard the LED power is connected to ground when the pedal is engaged. I've used this wiring schematic before with success, but just now noticed that my ground and LED complete a circuit when it's on, and wasn't sure if that was correct.
Measuring with 20V dmm
Q1:
G - 0.0
S - .9
D - 5.2
Q2:
G - 0.0
S - .95
D - 5.0
Q3:
G - 0.0
S - 1.5
D - 2.4
Q4:G - 0.0
S - .7
D - 6.8
Thank you so much - let me know if you need anything else.
