This is made harder by the fact that any one transistor has gain, leakage, etc that varies with conditions, including how you test it. The problem with testing transistors with different testing methods is how hard it is to get any consistent results at all. To get consistency, you have to go redesign the testers so the test conditions the transistor sees is identical.
And in fact, as I've said before, no transistor can boil down to a single number or set of numbers when it varies with time, temperature, current, phase of the moon. What a transistor test is is an indication, perhaps relative to other transistors you're testing at that moment on that same tester.
I did (compare).
I own a Peak Atlas DCA55, a DCA75pro and a MK-168 (new cheap chinese one from ebay).
Both PEAK Atlas testers measure Hfe with an quite high collector current for our puposes.
DCA55 (FW: R2.
HFE @ Ic= 2.5x mA
Vbe @ Ib=5.xx ma
Leakage @ unknown voltage (have to look up)
DCA75 (FW: 0018)
HFE @ Ic= 5.0x mA
Vbe @ Ib=5.0x ma
Both testers use a fairly fixed test point and if temperature is constant
and test probes have a good contact to the transistor leads (corrosion is an issue!)
test results have only small fluctuations. No moon phase :-)
Constant collector current means different Ib and a different resulting Vc for HFE measurement.
Useful collector currents for Fuzz Face Q2 would be around 0.5 mA (@ ca 5V Vc)
Example AC153 V Siemens:
Tester DCA75pro
Test Result:
PNP Germanium BJT
Red-C Green-B Blue-E
HFE=73 at Ic=5,01mA
Vbe=0,246V at Ib=5,00mA
IcLeak=0,151mA
from the curve tracing data (Vce= 5V):
HFE=43 at Ic=0,2 mA
HFE=48 at Ic=0,5 mA
HFE=55 at Ic=1.0 mA
HFE=62 at Ic=2.0 mA
HFE=71 at Ic=4.0 mA
HFE=81 at Ic=7.2 mA
This is an extreme example but it shows the problems.
Vbe is measured at a very high current (sometimes not useful).
Leakage is relative independent from voltages above Uce > 1-2 V
For the germans here (idomatic): Wer misst misst Mist. ;-)
("Who measures measures rubbish!")
Both the R.G.Keen-Method and the chinese tester are using a constant Ib for measuring HFE
resulting in HFE-dependent Ic and Uce (R.G.: Ub= 9V Rc = 2.472k Rb= 2.2M / MK-168: Ub=5V Rc/Re= 700 Ohm Rb=470k)
At moment I cannot comment on the accuracy of the MK-168.
R.G.s method is as accurate as resistor values and voltmeter.
And it is the fastest method for no/low leakage transistors
(beside a multimeter if you get the transistor leads in the right positons fast enough)
One could find the R.G. test point within the curvetracer data of the DCA75pro.
I don't know a tester which could test Hfe and leakage in one second and at once.
electrip
