Jeez Louise... you had me at "PLAY". Blowin' my mind man! I'm going to vero with this. Are there any special power considerations? Biploar, or straight up 9v?
I'm glad you like it
Just straight up 9v single supply. I would love to see a vero layout!
Just check the datasheets for power connections. It's +9v to either pin 14 or 16 and ground to either 7 or 8 depending on the size of the chip.
I made a few tiny changes to the schematic. A schmitt trigger as anotherjim suggested is one of them (thanks!).
It helps a bit with the sustain. It works ok now with hot humbuckers using neck pickup.
But with lower output pickups it would be a good idea to use a booster, compressor or distortion at the front.
Man, great stuff. Great site with low parts count projects that have massive sounds that are in the realm of what I dig.
Thanks! I gonna check out that anderton ringmod. Is it the one with the obsolete chip?
An effects loop would not really be possible to add with this one though, since it works with squared up signals
cheers / Freppo
