Author Topic: How do people connect their ground wires? Looking for new options  (Read 1587 times)
chumbox
Hi All
Now as a heads up, I understand how the ground wires are meant to connect and have built quite a decent amount of working stompboxes.  Just looking for new, easier or creative ways to ground my wires.  Generally I have my LED cathode directly soldered to a jack sleeve and then to my 3PDT footswitch, from there all my other ground wires kind of connect from the DC jack in a kind of loop from part to part.  Works for me but sometimes I feel like there might be a better way.  Do my Switchcraft jacks ground to a painted enclosure for instance so they don't need to run back to the DC jack at any point?
peterg
Re: How do people connect their ground wires? Looking for new options
« Reply #1 on: January 14, 2015, 06:52:30 PM »
I connect  the board, led, output jack and power jack ground wires to the input jack ground lug. If any pots are grounded I wire them to the board along with the other pot wires.
« Reply #2 on: January 14, 2015, 08:34:24 PM »
DC ground to board..
3pdt ground and another board ground to input jack...
no ground on out jack.. (i use bare metal boxes..) (i also put my on/off led/CLR on board too, with just a wire to 3pdt)
« Reply #3 on: January 14, 2015, 11:16:27 PM »
Like deadastronaut except on the last build the most convenient place to ground the input jack was to the ground lug of the nearby volume pot.
Add a battery and the arrangement changes.
Jdansti
« Reply #4 on: January 15, 2015, 01:30:05 AM »
If the interior of the enclosure is unpainted, the jack will probably be grounded. I usually run ground wires to the jacks just to make sure they are well grounded.
« Reply #5 on: January 18, 2015, 10:40:05 AM »
Get a DMM with continuity check and never wonder again!
