Author Topic: Quiet buffer  (Read 1223 times)
Hypnotize
Quiet buffer
« on: January 17, 2015, 11:11:47 AM »
Hi there :)
Today i build "klon buffer" using Tl072 , but it's quiet :(
What should i do to make it louder ?
P.S.
I used :
http://tagboardeffects.blogspot.com/2011/04/klon-buffer.html
P.S.S.
After removing 560r resistor , sound is a bit louder , but it's still quiet and most of bass is cut :(
nocentelli
Re: Quiet buffer
« Reply #1 on: January 17, 2015, 03:38:08 PM »
Is the input cap definitely 100n?
Quote from: kaycee
squeeze on the back and never open it up again
Hypnotize
Re: Quiet buffer
« Reply #2 on: January 18, 2015, 06:22:19 AM »
yap , should i lower the value of that cap ?
nocentelli
Re: Quiet buffer
« Reply #3 on: January 18, 2015, 07:01:33 AM »
No, I was just guessing if you're lacking bass and level you might have a 1n or 100p cap instead of 100n. Lower values than 100n might affect the frequency, 100n is plenty for full guitar range. That buffer should be unity, it might seem slightly brighter due to the fact you're used to unbuffered long cable runs dulling the treble slightly. A large level drop suggests a wrong value used somewhere, or a fault in the construction.
Quote from: kaycee
knutolai
Re: Quiet buffer
« Reply #4 on: January 18, 2015, 08:39:38 AM »
The first layout asks for a tl071 opamps (single opamp package). If you are building that, using a tl072 (dual opamp package) wont work.
« Last Edit: January 18, 2015, 08:43:50 AM by knutolai »
