Korg 'Nutube' - next generation vacuum tubes
Started by frequencycentral, January 28, 2015, 01:09:13 PM
GGBB
> Also this:
Interesting.
Most notable is the low-low-low current up to 40 Volts on the plate. I wonder if there is a mis-interpretation of the data. The wobbliness of HPF's curves is also curious; we expect small "contact potential" offsets and possible saturation, but not a lot of inflections.
Also the data extends far into the Positive Grid range. In conventional tube work this is a No-No for small-signal amplifiers. Yes, we can bend this rule, especially if we know the grid current and if we have powerful drive (19 penny opamps?).
Assuming "large" plate voltage and non-Positive grid, I get numbers like:
Mu about 20-30 (HPF gets ~15, noting it depends on op-point)
Transconductance about 1V/0.16mA = 160uMho = 0.16mS
Plate resistance near 160K
Plotting a loadline like 140V, 140K resistor, I squint a swing like 105V-135V or 30V p-p with a 2.5Vpp input, or gain near 12 into infinite load.
Certainly a useful Audio Amplifier. But we have these, cheaper. Is it a Tube Amp? Technically yes, but the data does not allow any guess of distortion or grid-blocking to say if it has "the mojo". If I smooth HPF's curves I do get the expected ~~5% THD near clipping; oddly if I use the raw data it looks like very low THD. And there is more to a tube than plate clipping, grid clipping, and 5%THD curvature.
patricks
Cool. Do you think they'll make a pentode version? ;)
pmillett
#24
The NuTube 6P1 is available to buy online now on eBay and www.nutube.us.  It should be an interesting part...
Good to see you here, Pete.
I think your link got clobbered in the innernet. (";" s/b ".")
Seller site: http://www.nutube.us/
More links--
eBay store: http://stores.ebay.com/nutubeusstore
KORG site on NuTube: http://korgnutube.com/en/
Quite complete datasheet: http://www.nutube.us/downloads/Nutube_Datasheet_31.pdf
More app-notes: http://korgnutube.com/en/guide/
stonerbox
#26
I guess all of you already seen this?   :D
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
potul
Quote from: potul on January 16, 2017, 06:24:34 AM
And the first VOX amps using Nutubes are here
http://www.voxamps.com/MV50
The store I work at is a Vox dealer and we just put in an order for a few of these. Eager to hear how they sound (and open one up so I can see these things) in person.
vince76
diy clones: Byoc Phaser, Dallas Rangemaster, Fuzz Face, RAT, Neovibe, Bassman 5F6-A, EH LPB, Big Muff, BSIABII, Valvecaster.
HAPPY TO SHARE
Quote from: vince76 on February 02, 2017, 04:14:18 AM
Hi,
did you heard it?
Not yet. Vox says they won't ship until the end of the month  :-\
TejfolvonDanone
Those datasheets look really badly made. For example several plots have conflicting title and axis label. :icon_redface:
...and have a marvelous day.
biogk
Guys, I got some news that Nutube is on sale in Japan.
Here are addresses of these shops.
http://korgnutube.com/jp/dealer/
BTW, what is the relation between the nutube 6p1 and the Chinese 6p1?
Welcome.
Probably none at all. The NuTube is really a display tube. Used as an "amplifier" it would be too pathetic to put into production. However Noritaki has excess production capacity, and KORG likes it, so it is being offered.
That link is Japanese and seems to be Japanese shops. I know I have seen a US/EU sales site but am not finding it now.
GGBB
biogk
Quote from: PRR on March 14, 2017, 10:50:52 PM
Welcome.
nutube.us is the English site, and it is expensive a bit.
I will try to buy one the next time I go to Japan.
rezzonics
Just received in the post 2 samples of KORG NuTube 6P1 triode for a DIY guitar preamp project:
rezzonics
#38
According to the Application Notes the gain is 14dB at 12V and 17dB at 30V, I would like to make a boost channel guitar preamp with some cranked distorted output. I plan to cascade two of them at 24V, should I add additional gain? Opamp or JFET amplifier? Where to place the additional amplification, before, after?
wavley
Quote from: rezzonics on May 19, 2017, 03:23:14 PM
Personally, I'd breadboard this one and see what it sounds like.  That way you can try all the things you would normally do with a twin triode, for example: series for more gain, parallel to see if it gets that jumpered Marshall sound (plus 30% more gain and lower output impedance), cathode follower for lower output impedance... you get the picture.  Then I'd probably throw a Fetzer valve on the breadboard with it and see how it sounds before and after.
That's what I would do if I ever had the time for such things.
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
