Maestro FZ-1A
Started by goatsounds, February 17, 2015, 02:52:30 AM
Cozybuilder
#100
For signal caps, as DA indicated, polypro is worthy. You might consider the Wima 1uF 50 volt cap (40 cents)
http://www.mouser.com/ProductDetail/WIMA/MKS2B041001C00KSSD/?qs=sGAEpiMZZMv1cc3ydrPrFwgzP98AO9idwFKwdAiDxsI%3d
Quackzed
I'm holding my breath and crossing my fingers for ya' Riinehart...
Riinehart
You guys are the best!
Ordered the caps, will put them in as soon as they come and will keep you posted.
Huge thanks again.
me too, quackzed.
(also, congrats on the upgrade to all 5 doughnuts.)
Riinehart
Huzzah!!! It's alive!
My most sincere thanks to you all, especially duck_arse and Quackzed. I could not have gotten this thing working without you.
I ended up ordering the tropical fish caps from Small Bear, and they finally arrived today. As soon as I put them in, everything was fine. In fact, it sounds quite a bit better than I remember. Maybe the caps were degrading for a while?
Anyway, huge thanks. I hope I can return the favor someday. And hopefully this thread helps someone down the road, too.
Cheers!
Quackzed
#105
Ahhh, Satisfaction!!!   8) 8) 8) 8) 8)
Riinehart
Ha! Yes! Exactly!! Thanks x1000!!!
now you can show us a photo of the working thing, insides esp. and good work (and get in and measure all the transistor voltages, for the database .... ).
Riinehart
absolutely -- will do.
which legs of the transformers should i measure? all of them?
anything else that would be helpful?
Riinehart
OK, here are the voltages at the transformers with the pedal (finally!) functioning normally:
Q1c: -1.29
Q1b: -.6
Q1e: -.6
Q2c: -.77
Q2b: -.06
Q2e: 0
Q3c: -1.19
Q3b: -.01
Q3e: -.6
I hope I've measured and written them correctly. If something seems out of whack, just let me know. I wouldn't be surprised if I made a mistake.
If there is anything else that'd be helpful to post, just let me know.
Here's a pic.
