Thanks guys!
I don't have any plans to sell the half-populated boards, sorry. I'm going to post the gerber files and maybe upload them into the OSHpark library.
I may only sell the rest of the bare pcbs i have left, pm me if you're interested.
->sajy_ho
i haven't installed it into a guitar yet. I just build it and want to do some testing. Strat users generally have more stress with access to the electronics
Ok, time for more testing:
1. Input impedance. I used a common method of building a voltage divider out of a external resistance and the input impedance of the circuit, measuring the amplitude of the signal on the scope:
When the blue signal is 50% of the yellow one, the Rseries (trimpot) will be equal the input impedance. After i found that spot i took the trimpot out and measured it's resistance:
The result was about 824kOhm @ 1kHz (test signal). Nice!
2. Output loading. I wanted to see how does the circuit behave when in typical recording situations, that is driving a typical mixing console line input (~10k Zin) and an instrumental input with higher input impedance (about 300k). I did the test with two amplitude values of the signal: large signal, about 1.7Vrms and small signal about 100mVrms.
Animated gifs show how does the output waveform change when the circuit drives different impedances.
Large signal:
Small signal:
This is actually a very nice experiment that shows how the driving capability depends on the amplitude of the signal.
Next, i took one guitar which has a Dimarzio Evolution humbucker in the bridge position in order to see if there will be any clipping. The output of the buffer was plugged into a Line/Instr input in my mixer. The first part is the 10k Zin line input setting. Clipping the bottom half of the waveform, as seen in the previous test is clearly visible. I switched to 300k Zin in the second part. The signal was nice and clean with no sign of clipping.
And a sound sample:
https://soundcloud.com/user8582335/oboard-buffer-testI think the circuit does the job it was designed for very well:
- provides high input impedance for the pickups,
- provides relatively low, but, perhaps even more important, constant within all the usable frequency range output impedance,
- does that at a very low power consumption.
One thing to watch out is the buffer should be rather plugged into inputs with Zin above ~30k, most of the guitar gear falls into that category. Well, maybe except a few rackmount FX processors which have 10k inputs and are causing problem with tube FX loops too...
I wonder if replacing the battery with two 3.7V Li-Pos, adding some smart energy harvesting circuitry would make it, huh, eternal?
