Author Topic: DiSCO - Dirty compressor and overdrive  (Read 31825 times)
Cozybuilder
Re: DiSCO - Dirty compressor and overdrive
« Reply #60 on: April 05, 2015, 02:35:57 PM »
I've had a chance to play with it a bit, you did a great job with this Sam! Now to paint a box for it (stripes?)
It should look a little better than this once boxed:
samhay
« Reply #61 on: April 07, 2015, 05:34:01 AM »
Can't decide wether to paint the box pink (distortion) or neon lime (compressor). Decisions decisions
Well pink and green stripes might look very cool, but you probably won't have room for many stripes if you are planning on building it in a matchbox.
Alternatively, if you mix pink and green, you get brown...
Glad you like it. I see we went to the same school of spaghetti monster breadboarding too.
samhay
« Reply #62 on: April 07, 2015, 05:36:15 AM »
I added Big muff's tone control to this but ended up omitting it, so I have to say you're right about no need for tone control.
Right now I'm working on a PCB for this circuit and will post it as soon as possible. It deffinitly takes a place on my pedalboard.
Thank you Sam.
Thanks for trying out some tone controls with it - I am generally quite nervous designing dirt boxes that don't have adjustable EQ, so it's great to see that there seems to be some agreement here.
A PCB would be great - doesn't look like a trivial build on vero.
Feel free to post it here if you feel like sharing.
samhay
« Reply #63 on: April 07, 2015, 05:38:50 AM »
I made the changes to my vero layout. :)
I had to compromise alittle to keep the size 1590B friendly,
so I didn't include the millenium switching and kept the comp LED as the 1.2 version.
cheers / Freppo
Nice job Freppo. I started laying this out on vero last week and quickly realised that it isn't a particularly easy circuit to route.
The 1.2 switching seems like a good compromise, and I would imagine most people will be happy to use 3PDTs anyway.
Freppo
« Reply #64 on: April 07, 2015, 01:58:10 PM »
I built up the vero layout today. :)
It works fine, except the symmetry switch.
With the SW4 / SW5 not connected it turns out a massive square-wave fuzz and has no response to any of the controls.
Correct me if i'm wrong, but don't you still need a 10K resistor from the inverting input to the output of IC2A?
I guess now it's turning into a comparator without it when the input/output isn't jumpered by the switch.
cheers / Freppo
Check out my building blog at www.parasitstudio.se
samhay
« Reply #65 on: April 07, 2015, 03:26:01 PM »
Sorry - that's correct. It looks like I forgot to add the 10k to the schematic (now updated).
It looks like you have enough room in your layout to add the resistor if you stand it up.
« Last Edit: April 07, 2015, 03:36:52 PM by samhay »
Cozybuilder
« Reply #66 on: April 07, 2015, 04:05:18 PM »
Wow, that 10K in the feedback loop makes a huge difference! Now the two switch positions are a lot more compatible. I thought I had miswired and was about to start troubleshooting, glad I looked at the thread first.
Freppo
« Reply #67 on: April 07, 2015, 05:10:52 PM »
Okidoki. I updated the layout and added the final version to the vero-archives in my blog :)
http://parasitstudio.weebly.com/stripboard-layouts/disco-dirty-compressor-and-overdrive
I had to make in one column wider, but it will still fit a 1590B if you put the layout sideways.
If it has more then 4 knobs I'll always go for a larger box anyway, but that's just my personal preference. :)
I will post some picture when/if I get around to boxing it.
Thanks again for sharing this project!
cheers / Freppo
samhay
« Reply #68 on: April 07, 2015, 05:23:58 PM »
No problem Freppo, and sorry about the schematic %^&*-up. I hope that the rest of the builds go without incident.
Side note. Freppo - I see you also did a layout for the 'Cherub'. If you built it, what do you think?
Freppo
« Reply #69 on: April 11, 2015, 07:12:32 AM »
I enjoyed your Cherub Chorus alot. It sounds great.
Just another project that I never gotten around to boxing.  :icon_rolleyes:
The only negative thing about the cherub (aswell as the dimension p) is that I find them are a bit noisy (hissy)
I think some hi end pre-emphasis at the front end and some roll-off at the end would reduce most of the hiss.
The pre-emphasis I have in both the Parasite Phaser and the Green Currant Tremolo helps to reduce the noise alot.
Just a thought, maybe worth experimenting with :)
samhay
« Reply #70 on: April 12, 2015, 03:58:44 PM »
Glad you liked the chorus - I have a Dimension P too, but can't remember how to drive it as I built one with too many options.
I may have got lucky with my build of the Cherub, but it is pretty quiet for a little box with a PT2399, a LFO, and a dodgy layout. My recording interface is playing nice this evening, so I dug it out and recorded a new sample: https://dl.dropboxusercontent.com/u/11996927/Cherub2.mp3
Any chance the hiss you hear is coming from the PT2399 (some are worse than others) - does it get louder with the mix knob?
In any case, it would only cost a couple or resistors and caps to add some pre- and de-emphasis, which is a good idea, so will add it to the list for a revision at some stage.
p.s. no shame in not having boxed it yet. I have mine in a blank box, and it doesn't look like I will be adding labels any time soon.
« Last Edit: April 12, 2015, 04:02:05 PM by samhay »
DougH
« Reply #71 on: April 14, 2015, 10:29:03 AM »
Sounds great!
samhay
« Reply #72 on: April 14, 2015, 05:03:10 PM »
Thanks Doug
« Reply #73 on: April 14, 2015, 05:54:48 PM »
Good work Sam and Freppo.
Two more to add to the list. It really does sound great too.
Rich
"Duck_Arse
otherwise, you might end-up with SOIC or gullwings, for surface mounts."
DougH
« Reply #74 on: April 15, 2015, 09:22:51 AM »
Yeah, you really did a great job capturing the compression and the touch-sensitive power stage distortion here.
samhay
« Reply #75 on: April 15, 2015, 05:12:25 PM »
Thanks - it was one of those ideas that worked better than I thought it would. Nice to have something that is a just a little different too.
Cozybuilder
« Reply #76 on: April 18, 2015, 02:28:58 PM »
Finally finished- thanks for one of my favorite pedals Sam! I really like this at the beginning of the chain- just a little OD sounds great with the other pedals, the compression really smoothes out the overall sound. Versatile.
« Last Edit: April 19, 2015, 03:08:22 PM by Cozybuilder »
samhay
« Reply #77 on: April 18, 2015, 02:41:42 PM »
Nicely done Russ.
I see why you went for 2 LEDs now - very period correct.
samhay
« Reply #78 on: April 23, 2015, 08:00:52 AM »
Just noticed another error in the ver 1.3 schematic, which I have now fixed.
SW2A (Symmetry switch) should only be shorting D3. As it was drawn, it was also taking D1 out of circuit when the switch was open - not the intendend function, so I have moved D1.
Freppo, in your layout, you will need to shift the anode of D7 (your labelling) down to the op-amp output - it will fit if you move it left 2 rows.
Russ, not sure how you wired your switch, but it will probably work better if you do it as now drawn.
Sorry guys.
Cozybuilder
« Reply #79 on: April 23, 2015, 09:01:55 AM »
This was the schematic I used, D1 is always in the circuit paralleling D2, D3 gets shorted. In your post above, the difference is that D1 will parallel the pair D2 and D3, or only D2. I can do that by switching the 2 leads to SW1A (D1 to SW1A center, and D3 to SW1A #3.) Right?
« Last Edit: April 23, 2015, 09:07:32 AM by Cozybuilder »
