Author Topic: ABDUCTOR II DELAY.  (Read 67594 times)
kurt224
Re: ABDUCTOR II DELAY.
« Reply #220 on: October 26, 2020, 06:44:50 AM »
Hi, could you share the single layer pcb? please. :icon_cry:
« Reply #221 on: October 26, 2020, 07:32:14 AM »
hi, there isn't a single layer for this....if there was it would be huge..
« Reply #222 on: October 26, 2020, 01:40:07 PM »
...and DA (the other) would complain about the image size.   :icon_rolleyes:
Still: huge, single-side, . . . I wonder if Dino's done a vero layout?   ???                                        ;D
11-90-an
« Reply #223 on: October 26, 2020, 07:23:51 PM »
Not Dino (I think) but this guy pulled it off...
http://guitar-fx-layouts.42897.x6.nabble.com/deadastonaut-abductorIIdelay-td29363.html
Now Iíll patiently wait for a perf layout... anyone...?  :icon_lol:
flip flop flip flop flip
« Reply #224 on: October 27, 2020, 09:13:22 AM »
I'm confused by which DA (to).
Now battery powered. Remove plug when not in use, please.
skyled
« Reply #225 on: November 05, 2020, 08:45:03 PM »
Here's my build report on the Abductor II delay over on Madbean's forum. I managed to add an effects loop in a way which can only be described as "stupid easy". Hope you guys enjoy  ;D
https://www.madbeanpedals.com/forum/index.php?topic=32001.msg307588#msg307588
« Reply #226 on: November 06, 2020, 02:41:24 AM »
Cool....no pics of your build?..
skyled
« Reply #227 on: November 06, 2020, 03:52:37 AM »
Green knobs for little green men.
« Reply #228 on: November 06, 2020, 04:51:08 AM »
looks great...nice build.  8)
the term little green men was apparently from a guy who said he witnessed  'little grey men' around WWII but he was miss quoted by the press and it stuck.... don't ask me how i know this...  ;)
gigimarga
« Reply #229 on: March 14, 2021, 07:47:07 PM »
Hello!
It looks like a fabulous delay...thank you for it, deadastronaut!
If I want to build it with true bypass, I can omit 2N5457 and the parts between its gate and +9V? Of course, I will put a wire between drain and source of FET.
Thank you!
« Reply #230 on: March 15, 2021, 03:29:07 AM »
Yep you can do that, no problem....
gigimarga
« Reply #231 on: March 15, 2021, 03:55:01 AM »
Thank you very much, Rob! :)
gigimarga
« Reply #232 on: April 10, 2021, 02:56:10 PM »
Hello!
I finished the Abductor and it sounds amazing, but I have a problem: the delayed sounds are distorted (most on the bridge position). I have an Ibanez RG370 unmodified, with Infinity pickups, but when I use it with other PT2399 delays (Multiplex, EQD etc.) I don't have this problem. I tested 3 types of PT2399 (different sources), including ones that don't sound distorted in other delays. The source of the problem could be the fact that I omitted 2N5457 bypass? I tried to find on Internet the drain-source resistance of 2N5457 when it's on, but I have no luck. Also, I added 4 yellow and green 3mm LEDs from pin 7 to ground as I saw in other builds (Jon Patton's idea) and the twos from IC1 and IC2 lights almost all time, while the last two lights weakly. Maybe I must add a trimpot insted jumpering 2n5457 drain and source? If yes, which value could be?
Thank you a lot!
