There are
functionally only 4 different ways to do it (at least I can't think of a fifth):
But
mechanically/physically there are many variations. CodeMonk's is the input grounding variation - and I think that's what most of use DIYers tend to do. I came up with a variation of it a while back that I use now because it keeps all the wire connections on the outside lugs (I use component lead for the small jumpers on the inside lugs):
Whenever I see
the last one the OP linked, I like to point out the uselessness of connecting the lower left lug to the two adjacent lugs - it is completely redundant, requires more work, uses more solder (and wire), and creates more opportunity to damage the switch from soldering heat.
