PWM and the Spinsemi FV-1
Started by aziltz, May 01, 2015, 06:21:12 PM
aziltz
Has anyone used PWM signals to drive the FV-1 pot inputs from a PIC or other microcontroller?  I'd like to hear the details
PWM + FV-1 or similar doesn't turn up any hits unfortunately.
Digital Larry
Haven't done it personally (yet).  Think it's a pretty valid approach.  Pot control inputs on FV-1 are supposedly 10 bit resolution, so for the best experience, have at least that in your PWM.
Digital Larry
aziltz
thanks.  Anyone else? Beuller?
Like Larry, I haven't tried it but it should work. In theory the internal low pass filtering on the pot inputs should convert the PWM signal into the equivalent of a DC level. If it doesn't work all you would need is a simple RC lowpass filter between the PWM output and the FV-1.
I've got a PWM LFO I've been working on, if I get time I'll try hooking it up and see what happens.
free electron
I have done that many times, although i haven't tried to feed the POT inputs with a pure PWM signal. I always filter them with a simple RC lowpass right at the MCU pins (=less noisy layout or less potential problems with other signals picking up these fast pwm transients). Just make sure the range is 0-3.3V.
peterv999
#5
The eTap2hw project is also, available with automation using PWM.
Piet
aziltz
Quote from: peterv999 on July 05, 2015, 01:36:34 AM
Piet
is the arduino program code available?
GuitarPhil
Quote from: aziltz on July 05, 2015, 09:50:49 AM
Piet
It's on my blog  :)
https://echotapper.wordpress.com/
Click on the 'Latest Updates Here' on the menu bar but you'll probably want to read some of the stuff on the blog too  ;)
We do use the PWM outputs to drive the Pot inputs but using a low-pass filter.
Phil.
aziltz
Found it!  Hopefully this will help me write a pot-to-pwm for PIC
GuitarPhil
Be careful if your running a 5V Arduino or the like as you'll need to have a voltage divider on the output of your PWM filters so it doesn't feed more than 3.3V into the FV-1 pot inputs.
Phil.
peterv999
Quote from: GuitarPhil on July 09, 2015, 07:36:18 PM
Phil.
The I/O board used for the eTap2hw automation includes this voltage devider and snubber to compliment Phil's software. Also, this board is a shield that accepts the Adafruit LCD shield with buttons or my 38mm I2C to LCD board if height is the limited factor using the Adafruit LCD shield.
Piet
www.echotapper.nl
