no more tone stacks for me..
Started by deadastronaut, June 21, 2015, 03:41:26 PM
well i tried a bjt buffer in front, no sound at all...this is weird..
(buffer works fine on its own )
tca
Quote from: deadastronaut on June 23, 2015, 04:54:51 AM
It would be nice to see the exact circuit that you are playing with... I guess is something like this?
But the problem might be (in) the details.
yep that's it...
(in) the details?... ???
i have a voltage divider and cap for vb if that's what you mean?..
tca
Don't see a problem there... it should work, as you say!
Can I ask if you did biased the opamp?
Cheers.
i have 4.5v going to vb points..
tca
Bad opamp? Bad BJT?
You could take the software engineering approach: take everything out the breadboard and try again. ;)
 ;D  yeah...
i'll go over it with another keen eye...
> i'm getting 8.12v on the in resistor
All points on the opamps and pots should *be* your Vb, +4.5V DC (assuming zero and +9V power).
Anything else is wrong.
The "Simple, Easy.." does not *need* a buffer for general use and happiness. However the input impedance is a little low to come right off a naked guitar with full highs, and the hiss level will be a bit high. A high-Z small-Gain amp in front may be part of the final configuration.
cheers paul,
hmmmm...
i think i'll go for a different EQ circuit then...so much for simple eh. ;D
Have you considered rgs parametric eq
Does it work lol... ;D
i just bought a la3600, i,ll give that a go,
but yeah i,ll take a look at that too...
armdnrdy
MrBinns
prametric eqs are so cool. I built and modified a pq-4 and loved it. I haven't tried rg's though. also I'm not op.
10 :icon_eek:...thats just greedy..
@mr binns ''also i'm not op'' ?
MrBinns
Quote from: deadastronaut on June 25, 2015, 04:05:27 PM
I'm not you(the op, the original poster).
tca
#36
Quote from: deadastronaut on Today at 06:54:50 AM
Quotethink i'll go for this... http://electronics-lab.com/projects/audio/018/
You will need to recalc the capacitors values to adjust Q and frequency response  for a guitar signal. The given values are for "regular" audio.
The details and howtos is in the datasheet: http://www.datasheetcatalog.com/datasheets_pdf/L/A/3/6/LA3600.shtml
P.S.
Not much different from this: http://www.diale.org/simple-eq.html
hi tiago, yep, i was looking at your caps/freq's for it.. 8)
very handy..cheers man.
(wont get chip till monday), but that's fine...i'll be recovering from a weekends camping and beer up.. :P
electricco
The best active EQ I built so far is the one into the Wampler Triple Wreck, Middle response is great but the best is the bass response on it !
....worth a try  :icon_cool:
tca
#39
Quote from: deadastronaut on Today at 11:06:53 AM
Quotehi tiago, yep, i was looking at your caps/freq's for it.. 8)
Accidentally, or not, R0 and R1 are the same... so you *can* use the same cap values for your chip. Looking forward to ear/see your build.
Cheers.
