"dip" painting enclosures-- one question
Started by plexi12000, July 11, 2015, 09:11:37 AM
plexi12000
well....first off, thank God it's the w/e!  lol
gunna try my luck at dipping an enclosure. i was looking at some pics on here- wow.  some REALLY awesome jobs.  so i'm inspired-
read the geofex procedure, sounds good to me, so i'm goin with that.
just one question..... should i dip each side? or do you dip the whole damn enclosure?  or either?  i really don't feel like cleaning out the inside.
Thanks mates--
GibsonGM
You mean the psychedelic trick with oil paints, to make the swirl patterns - swirl painting?  If so, I 'sink' the box on a coat hanger thru a pot hole into the water...add the oil paints to the water surface to make my groovy pattern...then slowly lift the enclosure back up thru the paint. Just one time...the sides get it too, if you make the pattern pretty large.  Carefully place on newspaper to dry...this way, there is no paint on the inside.
Sorry if that's not what you're looking for...
plexi12000
yeah!  the psych-look!  totally awesome-
ok...just checkin if i hear you right.  you dip the whole thing in..and THEN drip your paint on the waters surface?
GibsonGM
Yup!!  Make a 'hook' out of a coat hanger, pass it thru a pot hole and use it as a "handle"....then add the paint, pull it up...all set!! :)   Pics or it didn't happen (lol)
plexi12000
hahaha!!  aw, come on Gibby!  you KNOW it's gunna prolly suck!!!  lol
GibsonGM
No way, you got it!  My first try was...weird - so I quickly wiped it right off the box with a rag (the film is fragile)...then did it again, and it came out great.  Yours will too!
