Hi folks,
Here's the whole story. I finished my Forum Vibe v5 yesterday. It's the vintage build, using a 24V regulated power adapter, 24V to the LFO and 15V to the audio via 7815 regulator. I used Banzai Univibe LDRs/bulb kit, put the photocells flat. 2N5088 all around. Added Redhouse Gain mod and Bias-Offset trimmer. The vibe worked on first try.
The first thing I noticed was the limited range of the speed pot. I fixed that by the reducing the 4k7 limiting speed resistors to 1k5. I tweaked the trimmers and started to do A/Bs with my trusty Mojo Vibe. The FV sounded good, only lacking a bit of intensity to my taste. That's when I noticed the Vibrato mode was louder. At first it sounded like a volume boost but it's a actually a mid boost.
Here comes drama part 1
I decided to try to add a speed indicator led, Bob Sweet style.
(For the first time I ordered clear purple LEDs, and when I received them I was surprised the light was so dimmed with a 3k9 resistor I found out I could loose the resistor and have the same amount of intensity as a regular red LED + resistor.) So I was toying around with LED over the board and the speed pots, I managed to lit the LED a few times I think there were some sparkles involved too. I realized the bulb wasn't flashing any more. I immediately plugged in and of course the vibes have gone. Luckily, I had taken voltage readings of the first 10 transistors shortly before. They all looked fine, Q13 too but Q11 & Q12 looked dead. Trying to desolder those turned out to be a PITA; even with a desoldering pump; I gave up and clipped them. I used 2 old 2N5088 I had around and the vibe started working again.
Here comes drama part2
The mid boost was still there but what bugged me the most was the slight lack of intensity. I then decided to toy with the photocells. Once again a PITA to desolder. I desolder the bulb first, it looked very fragile. I had already clipped the leads of the photocells so I had to solder new ones. I put sockets on the board while I was at it and put back the photocells this time facing the bulb. I didn't gain intensity as I thought. It only made the vibe more choppy. I tried to tweak the trimmers but it was helpless. I don't know if it's the changing of the 2 dead transistors or the over-heating of the LDRs & bulb but the offset and lamp bias trimmers have lost a good part of their range.
I tried to angled the photocells but it didn't changed a thing. So back to putting them flat. But before that I needed to desolder the leads. I took care of removing the solder of the remainings leads in order to put them in the sockets. What was bound to happen happened. I broke a photocell lead straight at the base. After desperate attempts at soldering a lead back I caved in and faced reality. I'll be stuck until I got new parts.
So until I'll be waiting for them, do any of you guys have an idea regarding the mid boost. It may not be useful, but the boost happens in the cancel mod too. The electro caps and transistors are oriented correctly. I measured each resistors with a DMM before I soldered them. I'll give another closer look.
And finally do you think it's safe to give another shot at the speed indicator with my purple LED. Did and /or will I fry Q11 & Q12 again by putting this LED directly from Q12 emitter to ground
