Author Topic: Boss PS-6 Problems  (Read 1941 times)
latestsaint
Boss PS-6 Problems
« on: September 22, 2015, 11:33:08 AM »
Hey there,
I recently acquired a non-working Boss PS-6 Harmonist.  I couldnt find any schematics with a web search, probably because it is all SMD and extremely digitized.  Signal passes through the pedal in bypass mode and when the pedal is engaged.  I tested at various knob settings, still with no luck.  the LED lights up and there is always a signal passing through, just no effect.
Any ideas where to start debugging this thing?
Thanks in advance!!!
Hatredman
Re: Boss PS-6 Problems
« Reply #1 on: September 24, 2015, 09:06:11 AM »
You could start with the switching (bypass) circuit.
Kirk Hammet invented the Burst Box.
adielricci
« Reply #2 on: May 04, 2017, 03:10:14 PM »
I bought the PS-6 a few years ago, and it has never left my basement floor, and never fell, or had any strong collision. A while ago it started working partially, the major and minor pitch shifting/voices stop working, as well as the octave up part of the S-bend funcion. All the other functions work perfectly. For it to start working again, the only way is to bump the pedal on the floor, as if there is something loose or a crystal stops working.  Any ideas?
