Author Topic: Arduino MIDI Switcher  (Read 51884 times)
acatlow
Re: Arduino MIDI Switcher
« Reply #80 on: May 24, 2022, 09:50:03 PM »
Thanks for the reply niektb,
none of your suggestions for sw2Push actually worked. I need to change between channels and your way didnt "Go back to first case switch" so to speak... and I was still not sure about adding additional case switches to the buttons, which all i need to do is change the value from 1 to 3 for example...
I changed the digitalwrite functions to the start of the CC function, before the display message, but it wouldn't make a difference as there is no delay.
I did correct the delays in between the breaks though...
the delays were because the pads were too sensitive but I managed to figure out it was due to INPUT_PULLUP which i just needed to change the switches to LOW instead of HIGH and they aren't as sensitive anymore.
Here i've updated my code
Hmm weird, it should definitely work:
I should explain better... it did work, but only stopped functions after 1 press, and didn't cycle 0 to 1, 1 to 0
this isn't what I wanted, but it is working perfectly now and very quick functions from momentary switches.
so thanks very much for the help from everyone here too
Alex Catlow
Sirius Amplification
https://siriusamplification.com.au
