Author Topic: Tilt preamp  (Read 20734 times)
samhay
Re: Tilt preamp
« Reply #40 on: April 20, 2016, 07:23:23 AM »
1590B stuffed to the gills.
The LEDs and associated resistors are on a daughter board under the main one and the extra caps and pull-down resistors for the bass cut and crossover frequency switching are on another (vertical) daughter board connected to the 3 pots.
I have decided to keep the next few projects simpler.
Re: Tilt preamp
« Reply #41 on: April 20, 2016, 09:22:44 AM »
Marc - this works quite nicely with my fretless bass....
Useful to know - thanks Sam.  Perhaps another one for the backlog!   :D
Cozybuilder
Re: Tilt preamp
« Reply #42 on: April 20, 2016, 09:39:49 AM »
Nice tight build Sam! Happy to see the jacks on the back of the box, the anti-turn holes for the pots & switches, and those LED holes aren't bad looking. Is that etched or a waterslide or some fancy calligraphy? It looks good  8)
samhay
Re: Tilt preamp
« Reply #43 on: April 20, 2016, 10:22:16 AM »
Thanks Russ.
If it's worth building, it's worth building something that will last.
The labelling is a toner transfer.
Re: Tilt preamp
« Reply #44 on: May 08, 2016, 10:11:02 AM »
looks great sam...very nice :icon_cool:
ive been using toner transfers a bit lately....being lazy and not etching
but when its just for me toner transfer/clearcoat is more than adequate.. 8)
nice quick way of labelling.. ;)
samhay
Re: Tilt preamp
« Reply #45 on: May 08, 2016, 03:51:02 PM »
Thanks Rob.
samhay
Re: Tilt preamp
« Reply #46 on: April 25, 2018, 07:42:21 AM »
Necropost to re-post pictures that disappeared thanks to Dropbox's purge.
Apologies as some of these are quite large files (~1M). You should be able to see larger versions by clicking on them/'viewing' image in a new page/tab.
« Last Edit: April 25, 2018, 07:45:59 AM by samhay »
Re: Tilt preamp
« Reply #47 on: April 25, 2018, 08:19:47 AM »
It's funny how thing like this get lost and found.
Good thing we have got lots for heads on the forum to fill in the cracks.
samhay
Re: Tilt preamp
« Reply #48 on: April 25, 2018, 12:18:18 PM »
These pictures were never lost, just hiding.
Where I've put the pedal is another matter - it might be hiding too. Nice to be reminded to pull it out and have a play.
Xavier
Re: Tilt preamp
« Reply #49 on: November 11, 2018, 07:57:41 AM »
Another necropost here.
I am about to build this circuit , has anyone built it ? So far I have spotted a mistake in the layout (apparently). According to the schematic it's input to R1 (10M).
As per the layout, Input goes to R2 (1K) and then into R1, so I stopped there....
samhay
Re: Tilt preamp
« Reply #50 on: November 11, 2018, 04:43:43 PM »
Yes, I've built several using the posted layouts.
While placing the input resistor before or after the pulldown resistor is not entirely equivalent, it makes very little difference, so I moved to to make the layout cleaner.
As with any filter, I suggest you breadboard it to tweak frequencies to taste. I also wouldn't suggest you build the fully featured version as this is overkill.
I would stick with a single tilt centre frequency, keep the switchable bass cut, and set Zin to max (i.e. you don't need the pot). This way it's 2 pots and a switch. Without a few tweaks to the layout you could fit it in a 1590A if you were so disposed.
Xavier
Re: Tilt preamp
« Reply #51 on: November 12, 2018, 08:58:24 AM »
Hi Samhay, thanks a lot for the answer, and for posting this circuit !
I will build the simple version. I will use it in front of a Marshall JVM410HJS to clean some of the bass frequiencies before the distortion, to make it palm-mute friendly. It will be my "tight" pedal.
samhay
Re: Tilt preamp
« Reply #52 on: November 12, 2018, 04:48:38 PM »
No problem.
Good luck, and let us know how you get on.
Xavier
Re: Tilt preamp
« Reply #53 on: November 13, 2018, 04:44:38 PM »
I think I found a couple more issues, since I've been trying to debug for a while.
According to the schematic, center lug of the Tilt pot goes to pin 6 of the opamp. In the layout it goes to pin 2 of the opamp
Also, Level 1 and 3 should go to opamp pins 2 and 1 respectively. In the layout, Level 1 and 3 go to opamp pins 6 and 7 respectively.
Tilt 1 should also be connected to R7, but it isn't in the schematic....
I will try to redo the layout since I am very interested to finalize it..........
samhay
Re: Tilt preamp
« Reply #54 on: November 13, 2018, 06:05:36 PM »
I guess I switched IC1A and 1B in the layout as pins 2 and 6 are both inverting inputs and pins 1 and 7 are outputs. As long as pins 3 and 5 are also switched (or in this case connected to the same point) then it's not a problem as the 2 op-amps are equivalent.
Tilt 1 goes to Cx + R8 (1k) and C9 + R7. I've switched the order of C9 and R7 in the layout* - R7 is the 10k top right in the layout (I assume you can see R7 in the schematic above "TILT CROSSING"?).
*the order of components in series can be switched as long as nothing is connected between them.
Ben N
  • Total likes: 638
  • Ben N. - really! Now Israel, once Baltimore
Re: Tilt preamp
« Reply #55 on: November 27, 2018, 06:24:08 PM »
Similar to a DOD FX-10.
samhay
Re: Tilt preamp
« Reply #56 on: November 28, 2018, 07:24:38 AM »
Broadly, but the filter topology is different, which is the centre piece of this design.
amz-fx
Re: Tilt preamp
« Reply #57 on: November 28, 2018, 03:01:58 PM »
Sam, I like that input stage with the impedance control. I may steal that from you to use in some future project!  :icon_mrgreen:
regards, Jack
iefes
Re: Tilt preamp
« Reply #58 on: November 28, 2018, 03:08:18 PM »
The variable Input Z is really cool. Would somebody of you more experienced folks here mind explaining to me how it works? I don't really get it yet. It would be great to have a simple multi-purpose preamp with adjustable input Z for use with guitars, mics etc.
Thanks heaps!
samhay
Re: Tilt preamp
« Reply #59 on: November 28, 2018, 03:33:46 PM »
Jack, I'm sure I've borrowed a few ideas from you over the years, so please be my guest.
Iefes. The input impedance is 'bootstrapped'. I'm sure Rod Elliot can explain it better than I can:
http://sound.whsites.net/articles/high-z.html
