Orange Tiny Terror Jfet conversion
Started by Domin, June 26, 2023, 03:29:22 AM
Domin
Hi! I tried to convert this schematic into Jfet one with 3 gain stages and buffer before volume and tone control but gain stages have too much gain. Is there any way to lower it? I biased it to cca 1/2Vcc but even first stage distorts and its not clean
antonis
Quote from: Domin on June 26, 2023, 03:29:22 AM
Just by replacing tubes with JFets..??
(in the mean of no resistors/caps values alteration..??)
temol
What JFETs? Yo can try to lower the value of the 22u  in the first stage. Or remove the cap completly.
T.
Domin
Quote from: antonis on June 26, 2023, 07:10:37 AM
Im new into it so im just trying
Domin
Quote from: temol on June 26, 2023, 08:37:11 AM
T.
I removed all of them but at max settings it lacks gain
temol
Quote from: Domin on June 26, 2023, 05:18:45 PM
Start with a first stage only, not all.
What models of transistors are you using?
GibsonGM
Go look at Jack's JFET boosters at the AMZ site, linked at the top of the page here.   I think you might be able to do some kind of limited bypassing to get the gain you want.
Perhaps a 1k pot with a cap (wired as variable resistor) to ground in parallel with the source resistor...try simming it up or breadboarding!  Literally a pot in series with a cap, say 1u or 10u, to ground.   Pot wiper is connected to one of the outer lugs.   I played with a J201 boost doing this for a minute in LT Spice and it worked, but have to run out soon.
The value of the pot and cap are going to depend on what the final design is using for source resistance, and whether you want a 'full bandwidth' gain control or something more like a treble boost.  Once you find your 'topology', you build it on breadboard and try it out.
Domin
Quote from: temol on June 26, 2023, 05:30:28 PM
2SK117, they are from aliexpress so not that great but all of them have more gain
Domin
Quote from: GibsonGM on June 26, 2023, 05:39:13 PM
Ok ill try that, thanks
antonis
Quote from: Domin on June 27, 2023, 03:46:05 AM
And, of course, omit all those 68k grid stopper resistors..
(use them only in case of high-pitch oscillation, due to Miller capacitance, experience..)
https://www.diystompboxes.com/smfforum/index.php?topic=94071.0
Topic related to JFET high distortion..
https://www.diystompboxes.com/smfforum/index.php?topic=126575.0
GibsonGM
Yes, make the 'grid stoppers' a lower value or omit them :)      Limited bypassing is used often in tube preamps.
The gain control in a fuzz face is also usually done ALMOST the same, but you should have that kind of gain control in parallel with the JFET source resistance.  I hope I'm being clear enough that you understand...
antonis
Quote from: GibsonGM on June 27, 2023, 06:19:19 AM
Don't professional painters draw schematics, Sir..?? :icon_mrgreen:
GibsonGM
Have to run, wife needs me to drive her to work. However, I DID put something together!  This should give the idea.
An internet search would probably find more info on how this is done. (pot value, etc).
Domin
Quote from: GibsonGM on June 27, 2023, 06:49:24 AM
Yes I understood it, im gonna try it today :) Ill give you info
antonis
