Author Topic: Should I get a PIC programmer?  (Read 4522 times)
dbp512
« on: March 22, 2016, 07:34:13 PM »
I'm building a few circuits that require a TAPLFO chip, and the price at smallbear is over $35 with shipping and tax. Now I don't mind supporting Tom and his wonderful digital endeavors, but in the spirit of the whole DIY philosophy I thought why buy a few chips if I could instead buy the ability to make whatever I want. Especially because this batch of chips is about half the price of the programmer. I haven't done much with C beyond a text adventure, but I did pick up python, ruby and java pretty quickly. I'd be excited to learn, and it would allow me to expand into other endeavors (youtube has some fancy LED projects). But I don't know any of the hardware or software to use, so I'm not sure how much hassle it would be to get started. So I ask you, would jumping in with both feet like this be a good idea or is it easier to just buy the flashed controllers and not worry about programming things yet? From a purely monetary standpoint I don't think it would be worth it because I don't see myself building 7 or more digital based pedals in the near future, but it would give me the tools to build more things, and isn't that what we're going for here? In case you can't tell I'm super indecisive so writing this down helps to get my thoughts together. Any comments, advice, or suggestions would be appreciated, especially concerning the hardware.
Dave's not here, man
On some nights I still believe that a car with the gas needle on empty can run about fifty more miles if you have the right music very loud on the radio
 - Hunter S. Thompson
Digital Larry
Re: Should I get a PIC programmer?
« Reply #1 on: March 22, 2016, 10:10:33 PM »
My opinion: absolutely!  Keep in mind that I worked 15 years as an electronics engineer so I got my fill of building things and soldering irons and scopes.  After that. I got more into programming and it's a fun thing to do because it's almost constant mental problem solving without having to deal with the same level of pain for making a mistake, compared to hardware.
I discovered in the work world that hardware engineering has tons more risk avoidance/mitigation (e.g. peer reviews, design rule checking) so you don't spend $20,000 making a set of prototypes that will need to be thrown away because someone forgot to add thermals to the vias on internal ground planes (or whatever).
« Last Edit: March 24, 2016, 10:50:25 AM by Digital Larry »
Digital Larry
DSP tinkerer and former transistor twister
dbp512
« Reply #2 on: March 23, 2016, 12:34:21 PM »
Do you have any suggestions for a programmer? Would something like this work: http://www.amazon.com/dp/B004GRSZOG/ref=cm_sw_su_dp? Is it standalone or do I also need a PICkit? The PICkit doesn't have a DIP socket so it clearly can't program chips on its own, so what does it do? If there was a resource to get me started with all this I'd love to check it out. I tried to google, but I haven't found any guide that answer these questions. Thanks for any help you can give!
« Reply #3 on: March 23, 2016, 02:44:09 PM »
Yeah that programmer will do the job, it says it's compatible with MPLAB which is Microchips development/programming software so it will be a Pickit clone with a built in Zif socket.
A real pickit just has a header socket on it so to program DIP chips you just need to make a cable that plugs into the socket and then connect it to the chip on a breadboard.
The software you need is all free and can be downloaded here http://www.microchip.com/mplab/mplab-x-ide
samhay
« Reply #4 on: March 24, 2016, 06:18:16 AM »
short answer - yes
longer answer - I use one of these: https://www.olimex.com/Products/PIC/Programmers/PIC-KIT3/ and I don't have any reason not to recomend it.
« Reply #5 on: March 24, 2016, 10:09:26 AM »
Another "Yes!" from me. Grab a programmer, burn a few chips, build a few projects, and then start programming away.
I use a PICKit3. Even the genuine ones aren't that expensive, though the clones are less. Slacker mentioned that they don't power the chips, so you either need the chip powered up on a breadboard that you can connect the programmer to, or I have a ZIF socket for the same job. For prototypes on stripboard, I usually arrange things so I can program the uP in circuit.
Good luck!
Tom
PS: If you go down this route and have any trouble, drop me an email.
dbp512
« Reply #6 on: March 24, 2016, 01:47:29 PM »
Well the group opinion is a decisive yes, so I'm going to go for it. I'll most likely get something with a ZIF socket just to make things a bit easier, or at least give me the option as it looks like the one I liked to before has the pins for connecting to the circuit as well. One question I have, can a 16F688 run the TAPLFO code? Its pin compatible to the 684 typically used, but there are a few differences (I'm not sure if they're relevant).
« Reply #7 on: March 24, 2016, 02:36:22 PM »
I've never tried it, but I'd say not. The '688 doesn't seem to have Timer 2 or the PWM module.
Contrary to the usual Microchip "logic" the part with the higher number in this case seems to have a lower spec.
Tom
dbp512
« Reply #8 on: March 24, 2016, 03:07:06 PM »
Good to know. Thanks for saving me a couple of bucks!
grenert
« Reply #9 on: March 24, 2016, 05:29:30 PM »
Definitely makes sense to get a programmer if you plan on doing more than a one-off project, and really, there are so many projects that use PIC chips you're best off just getting the programmer.  Paying $15 for a pre-programmed chip (if it's even available) vs. $2 for a blank one and programming yourself can really add up.
I got a PICKit2 (seem to remember it had some advantage over the PICKit3 at the time), but I'm sure the PICKit3 is fine.  The software is very easy to use.
Ice-9
« Reply #10 on: March 24, 2016, 07:29:57 PM »
Definitely, go for it. It can open up a great deal of fun with many available projects, Gooligum has some great tutorials on PIC programing
Yeah, the Pickit2 has the advantage of being able to program EEproms as well, for some reason the Pickit3 can't. I have no idea if this restriction carries on to the clones of the Pickit programmers though.
www.stanleyfx.co.uk
It's fairly straight forward, if you want to start it , press start. You can work out the rest of the controls for yourself !
grenert
« Reply #11 on: March 24, 2016, 11:23:15 PM »
Ah, yes, that's it.  In fact, I probably use mine more for EEPROMs than for PICs!   :icon_lol:
hgamal
« Reply #12 on: March 25, 2016, 05:36:51 PM »
Another vantage of Pickit2 is the ability of programmer to select different programming voltages.
My FV-1 project uses 24LC32A attached to FV1 memory wires. As I have doubts if  FV-1 can stand 5 volts over those wires, I use the voltage selection feature to do the on circuit program of 24LC32.
See the command line bellow:
Code: [Select]
[hgamal@ygamal DSP]$ pk2cmd -p 24LC32A -M -A3.3 -Fhexout/dsp-nano.hex
Haroldo Gamal
Ice-9
« Reply #13 on: March 25, 2016, 06:37:53 PM »
Code: [Select]
That is good practice when programming an eeprom that is connected to a 3.3v FV-1 chip. There are other ways to connect the Pickit2 so that you don't need to worry in case you forget to change the voltage when other parts of the circuit are 3.3v like the FV-1 is. but I am getting OT.
www.stanleyfx.co.uk
