Author Topic: Diode Compression Opamp PCB  (Read 6839 times)
Macro_Ninjaneer
« on: March 28, 2016, 12:33:46 PM »
Hey guys,
First post here. I saw the diode-compression opamp and decided to make a small PCB version. Here is an image:
I wanted to make the PCB such that it fits into a standard DIP-8 package so it can directly replace a TL071 style opamp.
So far I have just done simple tests and everything looks like its working well. I want to build up a tubescreamer clone soon and use this opamp.
I ordered the board through macrofab.com (I work as an engineer there). The whole board assembled cost less than $10 not including shipping. Assuming the tube screamer works out I have plans to make a second version that has two of these opamps so I can use it as a drop in replacement for the standard dual-style packages like the TL082 or NE4558.
Joe
Re: Diode Compression Opamp PCB
« Reply #1 on: April 06, 2016, 06:33:52 PM »
This is really awesome, I intended to do a similar project years ago but never got around to it. I might suggest posting this on the main forum, otherwise nobody will ever see it.
Macro_Ninjaneer
« Reply #2 on: April 07, 2016, 04:11:09 PM »
I got the parts to build a tube screamer with this. Ill be assembling it tomorrow and ill post the results in main when its done.
Suicufnoc
« Reply #3 on: August 01, 2016, 07:52:17 PM »
How'd it go?  If you ever do the dual version, I may be interested in a few.
Sticks and stones may break your bones, but words can get you shot
Zose
« Reply #4 on: October 24, 2016, 03:12:35 AM »
Same here.
askwho69
« Reply #5 on: January 29, 2017, 04:57:01 AM »
Same here.
Same here
Sent from my iPhone using Tapatalk
"To live is to die"
eddie_bowers
« Reply #6 on: February 02, 2017, 01:57:10 AM »
Same Here. I just ran across this thread and I'm very interested in trying this out in just about everything that uses an op-amp just to see what happens :)
KR Audio
« Reply #7 on: May 17, 2020, 09:44:31 PM »
Very Cool Idea
