I'm really new to trying to build stompboxes, so I thought a line selector would be easy, and it was. The problem came when I tried to add a blend pot. For some reason it seems that I cannot find a good dry signal. Whenever the pot is in the middle it screeches loudly until I move the pot a little one way or the other. I get the wet signal fine and I can get the dry signal, fine it is just when the pot is right in the middle that I have the problem. I'm using a 250k pot if that helps. Please help! Thanks
Sent from my iPhone using Tapatalk
