Maybe it's been done before, I don't know. Cooked this up tonight. The build is the Knucklehead version of the Frantone Peachfuzz, except the PCB has no option for LED. I wanted something elegant, and pop free, so I whipped this up...
In a nut shell, it's this layout;
but 7 holes wide, to make up for the reach over the switch, and to split the power to the main board from here. Before you tell me that the FET is installed backwards, it's a 2N7000.
As for the switch, I cut the center (common) lug off the row holding the vero (
VERY IMPORTANT that you remove this lug), and trimmed the top and bottom pins to the point that they would fit in the holes. I had to spread them apart, ever so slightly, but there's enough pin that shows to solder.
There you go. Cheap and dirty, but it works.
