Author Topic: TIP29 fuzz  (Read 7871 times)
Re: TIP29 fuzz
« Reply #20 on: June 26, 2016, 09:59:50 AM »
I thought the "B" stood for "Bratwurst"...   :icon_rolleyes:
Re: TIP29 fuzz
« Reply #21 on: June 27, 2016, 07:57:04 PM »
Coming late to dinner...
> how come Q1, with grounded emitter, is only 250mV at the base?
2N3055 is a nominal 15A part. 15,000mA!
Here it is run at 8V/22K= 0.3mA.
40,000 times smaller than it "could" do.
Junction drop changes 20mV for 2:1 change of current, 60mV for 10:1 change.
60mV+60mV+60mV+60mV+20mV+20mV= um um um 280mV.
Taking "600mV" as the nominal junction drop at "intended" current, this super-tiny current should cause Vbe=320mV.
Which is in sight of 250mV. But not quite there.
More complication: 2N3055's Vbe at 15A is over a Volt, not 600mV. But much of this excess is stray resistance which drops-out at very low current.
Fiddling in SPICE with Duncan's 2N3055 model, I do not get Vbe as low as 250mV. More like 450mV. Taking the no-parasitic Vbe of '3055 at 15A (which is really socking it to the Silicon) as ~~730mV, this does come out right for 0.3mA.
Another way to "drop Vbe" is to take the collector WAY high, near breakdown, so C-B leakage dominates the junction. But for '3055 that would be way over 60V, and he's only got 9.5V.
TIP29 should not be majorly different.
Do not know why Gus' sim shows 250mV. Can't really care.
Re: TIP29 fuzz
« Reply #22 on: June 28, 2016, 10:51:40 AM »
as ever, thanks paul.
"Simple words - Bob, forget the rangemaster. Remember them - I can smell ceramic, believe me. Where did that Roy bloke go, Bob?"
"Get what you came for, the meadows can wait" -Verdelle Smith
Gus
Re: TIP29 fuzz
« Reply #23 on: July 09, 2016, 12:33:16 PM »
Finally finished putting the circuit in an enclosure
Measured voltages
Q1 base .54VDC
Q1 collector 1.5VDC
Q2 collector 7.28VDC
Supply voltage 9.66VDC
Cozybuilder
Re: TIP29 fuzz
« Reply #24 on: July 09, 2016, 12:50:33 PM »
Photo?
Gus
Re: TIP29 fuzz
« Reply #25 on: July 18, 2016, 11:37:58 AM »
recent builds clockwise from top left
silicon supa like
PN2222 one control fuzz 1.6VDC 7VDC
TIP29 one control fuzz
4 control fuzz with input cap selector switch
over the top BMP
another one control fuzz
The one controls have different biasing and other adjustments. I have a few more built that need to be boxed.
Gus
Re: TIP29 fuzz
« Reply #26 on: August 29, 2018, 10:55:21 AM »
A bump because I have not seem much about power transistor overdrive or fuzz circuits
tubegeek
Re: TIP29 fuzz
« Reply #27 on: January 25, 2020, 11:44:57 AM »
I just got in some TIP31 and TIP32 for my mini amplifier project, I might well try this thing at some point. So just a little re-bump to say Thanks Gus for all the interesting design work!
Re: TIP29 fuzz
« Reply #28 on: January 25, 2020, 02:13:06 PM »
One knob, two transistors? Shoot, this sounded like it should fit in a 1590LB. It does.
2N3055 Q1, TIP31c Q2, BS170 Millennium Bypass, Wima 1uF poly out, short Panasonic 100uF 16V electros; trimmed jacks & transistors, ⅝" standoffs with 2-56 screws; and a bit of head scratching to make it all fit. (& yes, it was worth it)
Cheers and thanks to Gus for another interesting, great sounding design
I was going to make a snarky comment and ask "But can it fit in a 1590A?".  However, clearly it can, with a bit of planning and wise jack/switch choice.
Re: TIP29 fuzz
« Reply #29 on: January 25, 2020, 04:11:23 PM »
Cozy builder did some great builds.   He always raised the bar on what could be done.    It's all hand-wired stuff, not two-sided boards and SMD parts.
The answers are out there for those who want to find them.
tubegeek
Re: TIP29 fuzz
« Reply #30 on: January 25, 2020, 04:45:57 PM »
Stuff like this blows my mind. I have trouble fitting some builds on my workbench.
Re: TIP29 fuzz
« Reply #31 on: January 26, 2020, 06:51:20 PM »
This is good - the low bias voltage of germanium without the leakage current.
2N3055 has now become a catch-all number for power transistors that do not quite meet the specifications of later power transistors so if, say, Hfe was too low, it might get packaged as a 2N3055 rather than whatever it was supposed to be.  Manufacturers sometimes do their own counterfeiting.
Re: TIP29 fuzz
« Reply #32 on: January 26, 2020, 07:09:04 PM »
Some years back there were fake 2N3055's effectively 2N3904 rating transistors inside.  They test out OK but when you
put any sort of load on them they fry.
edvard
Re: TIP29 fuzz
« Reply #33 on: January 26, 2020, 10:35:00 PM »
Well bust my buttons, I've thought of this kind of thing many times but never took the plunge.  Nice!
I'd like to see a build with 1/2 watt resistors and bumblebee caps around two big ol' TO-3 transistors, woop!!  :icon_eek:
All children left unattended will be given a mocha and a puppy
tubegeek
Re: TIP29 fuzz
« Reply #34 on: January 27, 2020, 04:13:17 PM »
OK, so digging through the Miscellaneous Old Semiconductors stash I got a few years back, I find a bunch of useful items. Just pulling out the TO-220's as a starting point
NPN's:
TIP3055's with hfe's of 229, 179, 193, 108, 73
MJE3055; 19
EP2437; 16, 13
MJE5984; 37
And a fair few PNP'S as well.
Starting with the 108 and 179 TIP3055's for now.
Re: TIP29 fuzz
« Reply #35 on: January 30, 2020, 08:57:03 PM »
The large devices have a *lot* more capacitance which smooth out the sound of silicons.
tubegeek
Re: TIP29 fuzz
« Reply #36 on: January 30, 2020, 09:28:00 PM »
Is there much to be gained in that regard by going from TO-220 to the big TO-3 package types? (I don't happen to have any TO-3 on hand at the moment.)
highwater
Re: TIP29 fuzz
« Reply #37 on: January 30, 2020, 09:36:05 PM »
If they're the same part number in a bigger package, not likely. The capacitance could even be slightly *less* simply because the leads (and bonding wires inside) are farther apart from each-other.
"I had an unfortunate combination of a very high-end medium-size system, with a "low price" phono preamp (external; this was the decade when phono was obsolete)."
 - PRR
mac
Re: TIP29 fuzz
« Reply #38 on: February 01, 2020, 11:02:50 AM »
Try those inside low consumption lights, hfe: 20. Good for darlingtons.
mac
