Author Topic: Normally open -> normally closed  (Read 1842 times)
grnbstrd01
« on: September 08, 2016, 06:44:16 PM »
I'm about to build a foot switch the same as a Digitech FS3X. I believe I need normally open switches, i have some normally closed momentary switches laying around... Is it possible to make a n/c switch act as a n/o at all, or in this instance?? (FS3X)
Thanks.
Sent from my iPhone using Tapatalk
mdeffects
Re: Normally open -> normally closed
« Reply #1 on: September 12, 2016, 08:51:00 PM »
Do you have a digital MultiMeter? Also, I'm assuming that you are using SPDT switches? If possible, use your multimeter to determine which switch is always on and just reverse them in the circuit if that makes sense. I hope this helps!
I own and run M.D. Effects, check it out here: http://www.mdeffects.net
grnbstrd01
« Reply #2 on: September 12, 2016, 09:07:16 PM »
Thanks MD I'll see if I can make that work.  Yes meter, yes SPDT.
mdeffects
« Reply #3 on: September 13, 2016, 02:46:25 AM »
No problem! I hope it works out! Let me know if it works
