Has anyone ever traced the Funk-a-Duck?
Started by digi2t, October 03, 2016, 12:55:01 PM
digi2t
Just wondering. I have one headed my way, so I thought I would ask before immersing myself too deeply into it.
Sounds like a resonator with an envelope detector on the front end. I'm curious to see how much (if any) of the resonator circuit is in there.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Can't wait to hear that please Dino. I'm curious about what's inside now too.
rutabaga bob
Life is just a series of obstacles preventing you from taking a nap...
"I can't resist a filter" - Kipper
digi2t
I'll post gutshots as soon as it hits my bench. I'll have to make a clean spot first though. :icon_mrgreen:
Dead End FX
rutabaga bob
Watched a quick demo and read some reviews.  This is powered on 16 volts?   :icon_rolleyes:
I have confidence in your abilities...you'll figure a way to use 9 volt power!   ;)
digi2t
Quote from: rutabaga bob on October 03, 2016, 03:24:02 PM
Didn't bother. The Resonator works off the same power scheme (16vac adapter > +/- 15vdc), and that's what we used for the Tresonator build.
Dead End FX
I miss Paul Perry.   :icon_sad: :'(  I hope he's doing okay...somewhere.
rutabaga bob
Didn't realize there was anything else using that scheme...my bad...
digi2t
If I'm not mistaken, I think that the 16VAC power was used so as to increase the available headroom. Lots of folks use these pedals with big signals (i.e. deejays, synths, etc.), so more room between the rails cuts down on the distortion.
Quote from: Mark Hammer on October 03, 2016, 06:01:45 PM
The last I read, he was running a bookshop in Melbourne.
https://www.muffwiggler.com/forum/viewtopic.php?t=89861&sid=66da93f1255131e506338efb994ef1fc
Dead End FX
Strategy
funk a duck is like a one-channel resonator switchable between high and low-pass...whereas resonator you get both at the same time. would also LOVE to check one of these out! When on ebay and such they tend not to command prices as high as the other frostwaves...
Strategy
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
digi2t
Funk a Duck is in da house.
Going to open it up tomorrow.  :icon_cool:
Dead End FX
digi2t
Sorry... took me longer than expected to get it open. Simultaneous Lab Series preamp, and Son of Storm Tide flanger builds might be to blame.  :icon_lol:
Here are the first pictures. Like I said, I'm kind of wrapped up in two monster builds right now, so I'll be slow to trace it. At first glance though, it does look like half of an MS-20 style filter section, with and envelope detector on the front end. I tried it, and it sounds pretty good, but I find that the envelope is rather picky when it comes to pick attack. You have to be fairly constant on the attack, or else it gets kind of hit or miss. I should have put The Engineers Thumb in front of this, it probably would have done a fine job of stabilizing things. Power section looks to be basically copy/paste of the Resonator. Straight forward +/-15v made from 16vac. Anywho, on with the show....
Dead End FX
rutabaga bob
digi2t
Well, here's the first tracing. Gonna sit down and draw out a schematic now.
Dead End FX
Cozybuilder
It looks like a photo of the component side- double check the pinouts of the transistors. E=C?
digi2t
Quote from: Cozybuilder on November 07, 2016, 07:11:28 AM
Dang Russ! You might be right... I think I got flip-flopped.  :icon_confused:
I'll check it tonight.
Dead End FX
digi2t
The transistor pinouts are backwards on my first draft. Here's the update;
I'll get all the component values up soon.
Dead End FX
digi2t
Here you go folks. Sorry about the messy layout, but I always sucked at laying out schematics.  :icon_rolleyes:
The double 0 ohm resistors are there because they're on the board. The "Env out" and "Bypass" boxes are open pads on the board. I just drew it like I saw it, that includes the bypass switch setup, which is something that I've never seen before. If you see anything hinky, let me know and I'll check it out. If anyone wishes to clean this up, by all means...
Dead End FX
I may have it wrong, but take a look at the Korg Monotron VCF - supposedly based on the MS20 filter - and it may help to make a little more sense of Paul's filter in the F-A-D.
https://amazingdiy.files.wordpress.com/2012/03/md-schematic.jpg
