Author Topic: Dating a JRC4558DD in a Boss sd-1  (Read 6861 times)
AgentDouble
« on: November 13, 2016, 09:44:45 AM »
Hello folks, forgive me if i post in the wrong section
I have bought a beat up Boss sd-1 and i would like to date it, but the bottom sticker is missing
The other sticker is "use boss ACA only" so i assume it is pre-1997
I looked inside and there is a JRC4558DD stamped 0301B
Can you help me to decode the date of manufacture of the IC ?
Thanks for help
Best regards
Les Turnbull
Re: Dating a JRC4558DD in a Boss sd-1
« Reply #1 on: January 23, 2017, 09:04:43 AM »
Not shure on the chip date but the capacitors are often dated .
« Reply #2 on: January 23, 2017, 06:21:23 PM »
I can't say for certain about the chip you're talking about, but chip date codes are often "year, week number" or vice versa. So, for example 8732 is the 32nd week of 1987. If that was the case for the one you've got, it'd either be the end of January 2001, or the beginning of January 2003.
There are other systems however, and not all chips are date coded…YMMV.
HTH,
Tom
« Last Edit: January 23, 2017, 06:23:39 PM by ElectricDruid »
AgentDouble
« Reply #3 on: March 29, 2017, 03:01:18 PM »
Thanks, but as i said, the pedal wears the ACA sticker, so it is obvious that the pedal is pre-1997. In fact, i did extensive research and with little info gathered, i assume that the first digit is the year code. In that case 0 wouls mean 1990, wich is very plausible. The last three digits along with the letter is batch number. It's a pity that the 4558 is such common IC and so little documented.
Ice-9
« Reply #4 on: May 05, 2017, 04:22:15 PM »
The 4558 is just a cheap as chips vanilla op amp, there is no mojo involved in dating the IC other than dating interest. You seem to have successfully(ish) dated the pedal due to the ACA psu requirement.  :icon_wink:
www.stanleyfx.co.uk
Vivek
  • Total likes: 336
  • Do good for others, good will happen to you !
« Reply #5 on: November 03, 2020, 02:32:57 PM »
Dating an IC chip is fun if you are into legs !
« Reply #6 on: November 04, 2020, 09:12:13 AM »
short legs. and a dimple.
no, I don't do kitchens ......
but pinkjimi's gonna help me with the measurements soon.
Ben N
  • Total likes: 471
  • Ben N. - really! Now Israel, once Baltimore
« Reply #7 on: November 04, 2020, 09:43:22 AM »
Flowers, dinner and a movie.
