What resistor for 3mm LED?
Started by steveyraff, February 19, 2017, 11:31:15 AM
steveyraff
What the title says. I usually use a 2.2k resistor for pedals with 5mm LED's. I built one with a 3mm and it seems a bit dim. What is the best value to use for this size of LED?
Thanks,
Steve.
Steve.
www.outlandstudios.co.uk
LiLFX
Quote from: steveyraff on February 19, 2017, 11:31:15 AM
Thanks,
Steve.
Depends on the forward voltage and current spec for the LED. Measure the voltage drop across the led...let's say it's 3 volts. Take your supply voltage and subtract the voltage drop (forward voltage) of the LED. Divide that number by the forward current spec for the LED. This gives you the smallest possible resistor that you can use with this LED. Adjust larger to limit current (brightness).
Just for practice. If your supply voltage is 9v, the forward voltage is 3v, and the forward current is 20ma. (9-3)/.02 = 300R
J0K3RX
Downlaod Electronics Assistant.. It's free!  :icon_wink:
It has a LED series resistor calculator as well as a bunch of other useful calculators!
http://www.electronics2000.co.uk/download.php#assistant
Or, you can just use the web based version.
http://www.electronics2000.co.uk/calc/led-series-resistor-calculator.php
merlinb
#3
Calculators are fairly meaningless as LED brightness is independent of voltage, and current specs tell you next to nothing about how the LED *looks*. They can tell you the minimum resistance before the LED burns out, but that is normally way beyond what you actually need. There is no correct value for a certain 'size' of LED. Diffusion, efficiency, viewing angle, mounting position, all matter. Only way to know what looks best is to try a few different values.
I do it by sight, i've scads of unsorted LEDs of various sizes, colours and from various suppliers. I plug them in and test 'em as i need them. Slider adds a 10k in series. From bits and pieces lying around waiting to be used.
dave
I'm with Merlin and Dave - try it out.  It's the quickest breadboard circuit you'll throw together.  I got one of these tiny things from Tayda which is perfect for this:
And yeah, be "careful" of the online calculators.  As Merlin says, they tell you a minimum - which will likely be bright enough to kill small children.
Read carefully ALL the above answers...!!  :icon_wink:
and grab then a 1k5 resistor to do your job..
GiovannyS10
Quote from: bluebunny on February 20, 2017, 02:39:27 AM
LOOOOOOOOOOL!!! Man, i really laughed a lot.  :icon_mrgreen: :icon_mrgreen: :icon_mrgreen: :icon_mrgreen: But i am with you, one friend sent me some blue leds and i have to use 33K for this ones 3mm LOL! And here i buy some that i use only 1k ;) Any questions? Only breadboard it!
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
www.instagram.com/allecto
