Author Topic: I hereby reclaim this hideous enclosure  (Read 41575 times)
pure_analog
Re: I hereby reclaim this hideous enclosure
« Reply #180 on: December 13, 2017, 07:20:19 AM »
Personally I think Dirty Sheet is great.
« Reply #181 on: December 13, 2017, 07:42:44 AM »
I do too.  I think my ultimate criteria are that the name should be suggestive rather than blatantly obscene, but not too suggestive that I have to hide the pedal from my kids so they don't repeat the name of the pedal out of context.  Dirty Sheet definitely works.
"I want to go back to being weird. I like being weird. Weird's all I've got. That, and my sweet style." --Maurice Moss
« Reply #182 on: January 28, 2018, 04:32:22 PM »
A small update.  As I've said in another thread, in 2018, I'm trying to advance or abandon older projects.
I've sanded off the yellowish Polycrylic failure, and I've purchased some gloss white spray paint.  My previous $0 budget for this project was just not going to get it done.  I'll probably purchase a cheap toaster oven to assist in finishing this and other projects.  (I've temporary removed the magnets from this enclosure so I can bake the finish.)
I haven't yet sprayed on the white paint.  I'll probably apply one more light coat of primer first (some of my sanding exposed bare aluminum).
« Last Edit: January 28, 2018, 04:40:39 PM by EBK »
BetterOffShred
« Reply #183 on: January 28, 2018, 07:05:23 PM »
My second hand toaster that was used to cook food for 10 years before being repurposed again to bake enclosures gets a workout.  It's looking good man. I went back and read this entire thread a month ago or so.. pretty fun man.
mth5044
« Reply #184 on: January 30, 2018, 10:48:04 AM »
This thread is amazing. Another vote for Dirty Sheet.
« Reply #185 on: February 21, 2018, 11:49:40 AM »
Rare planetary alignment today!  It is warm enough and dry enough outside for painting.  Wish me luck!
« Reply #186 on: February 21, 2018, 01:25:03 PM »
Wish me luck!
Seriously though, good luck! ;D
"I'm not sure what "serious design flaws" you see. Does it explode or poison your dog?" - PRR
« Reply #187 on: February 22, 2018, 10:24:02 AM »
I managed to get a few light coats of paint on that enclosure, and I even got to bake it in the oven (my wife wasn't home to yell at me  :icon_razz:).  It is a bit textured though.  Does anyone know if that can be smoothed out with polishing paper, or will it lose its gloss if I try that?
BetterOffShred
« Reply #188 on: February 22, 2018, 03:19:00 PM »
what I typically do is coat my color, bake, wet sand with like 400, coat another color, bake, wet sand 400.. then I clear coat, bake, wet sand 400, and then clear coat one last time and bake.. and hope for no fur  8)
If you're using gloss paint, any sanding will definitely make it dull, but gloss clear over the top will make it pop.
« Reply #189 on: March 27, 2018, 11:20:46 AM »
Minor update:
 I now finally own a second-hand toaster oven!  I will be able to paint again as soon as I find my long extension cord to turn it into an outdoor toaster oven. :icon_wink:
I should also probably measure the lowest temperature setting before using it.  The lowest marked temp on the dial is 250F (121C), but the dial has some unmarked range below that.
« Reply #190 on: March 27, 2018, 09:36:00 PM »
http://sluckeyamps.com/smoky/smoky.htm
« Reply #191 on: March 27, 2018, 10:10:31 PM »
Paul, you've extended the list of my lifelong ambitions with that.  The good news is, in the words of Stephen Wright, "I intend to live forever.  So far, so good."  :icon_wink:
Paul Marossy
« Reply #192 on: March 29, 2018, 01:21:39 PM »
Love the concept with the viewing window and the artsy componentry.
« Reply #193 on: March 29, 2018, 05:21:11 PM »
To be clear: That oven-amp is NOT my build. I saw it on another forum. My repurposing only runs to fitting a video-switch box with relays and resistors as a furnace control. (Well, I did build a PC into a side-table once...)
« Reply #194 on: March 30, 2018, 09:21:46 AM »
Aw, you can't go dropping nuggets like that, Paul, without backing up with pictures!   ;D
iiimonfire
« Reply #195 on: April 01, 2018, 10:36:37 AM »
Officially following this thread. I'm just here to see how these incredible projects turn out. My jaw hit the floor several times.
Enjoy the ride. --B. Hicks
« Reply #196 on: October 18, 2019, 06:27:09 PM »
Desperate to motivate myself to make some sort of progress with this project, I bought some new hardware for it:
If you are just joining this thread already in progress, I should let you know that it comes with a NSFW warning.  The project is the most inadvertently dirty project ever, by my subjective measure, and the thread contains numerous sexual euphemisms and innuendos.  Not my fault.  As I've said before, I blame the paint.
So, when someone seems to be giggling uncontrollably while pointing out that there's a crack on that knob, you'll understand why.   :icon_razz:
« Reply #197 on: October 19, 2019, 07:37:37 AM »
You were screwing too vigorously.  :icon_rolleyes:
« Reply #198 on: October 19, 2019, 07:50:11 AM »
It came like that.   :icon_razz:
(Once again, this stuff accidentally writes itself.)
« Reply #199 on: October 19, 2019, 05:19:10 PM »
I'll bet it did.   ;)
