Author Topic: How many farad capacitor formula  (Read 2239 times)
preciousmolina666
« on: February 27, 2017, 06:28:15 PM »
how many farad do i need and allowance should i need?
single stage, non inverting opamp consume 30ma and the other seperate pedal is bjt 10ma
I hate noise...
robthequiet
Re: How many farad capacitor formula
« Reply #1 on: February 27, 2017, 06:34:32 PM »
Not clear on where the Farads are needed in the circuit. Do you have a schematic we could look at?
preciousmolina666
« Reply #2 on: February 27, 2017, 06:55:30 PM »
i mean in single power supply pin of single opamp 5534, im using 10mf and i hear no problem but its so big ;D
upload when i got home
« Last Edit: February 27, 2017, 07:12:05 PM by preciousmolina666 »
I hate noise...
antonis
« Reply #3 on: February 28, 2017, 05:50:28 AM »
In single supply Op-Amp you need a 100nF ceramic capacitor for PS decoupling..
BIG capacitors lie right after PS rectification (sometimes with a small series resistor before them - to create a low pass filter..)
Anyway, a rule of (fat) thumb is 10.000μF per Ampere (or 10μF/mA)..
For your demands, a 470μF (with an optional series resistor of 10 - 47 Ohm - the lower the value the less the voltage drop..) should be fine... :icon_wink:
P.S. Not lower than 6R8 for 60Hz and 5R6 for 50Hz mains supply, with the 470μF cap...
« Last Edit: February 28, 2017, 06:02:00 AM by antonis »
preciousmolina666
« Reply #4 on: February 28, 2017, 05:14:42 PM »
thanks now i can finally now put my project in stomp box
I hate noise...
