Add a Dry Kill Switch to Earthquaker Devices Afterneath Mod
Started by BBBehring, March 09, 2017, 06:44:39 AM
BBBehring
Hey,
I'm new to this Forum and first I want to say hello to everybody.  :)
As the title say, I would like to add a Dry Kill to the Earthquaker Devices Afterneath. Cause I want to use it as a Send/Return Effect on my Mixer for DJ Sets. On the Earthquaker Website they say "Mix: Blends the wet signal into the dry. Though it does not actually go full wet, it will gradually lower the clean level as you turn it clockwise and give the appearance of full wet.", but I can't buy the Pedal without being sure that I can add a fully Dry Kill Switch to the Pedal.
I think it's not that a big Deal to add this Switch, but I'm confused by the inside of the Effekt and this Mix Poti which does't kill the Dry Signal totally. Since I don't need the Bypass function, I don't care if it's not working anymore, when Kill Dry On.
For pictures inside the box click:
-> http://www.gitarrebass.de/wp-content/uploads/2016/03/Earthquaker-devices-Pedal-innnen.jpg
-> http://atomiumamps.tumblr.com/image/138619066331
I would be so happy if somebody could help me, because i think this Effect could fit very well with mixing Elektronic Music.
Thanks a Lot
Best Wishes
