Converting 9v battery power to 2.1mm wall adapter
Started by prscrptn, April 04, 2017, 04:05:13 PM
prscrptn
Tired of batteries and want to convert power to a 2.1mm wall supply, but not sure what needs to be added to the circuit...
Do I need to add a regulator and filter to the supplied voltage before it hits the circuit, and if so what is required?
thermionix
Quote from: prscrptn on April 04, 2017, 04:05:13 PM
If you use a good quality power supply, it will be sufficiently regulated and filtered, and you won't need to alter your effect circuits, except maybe add a power jack.  If you use a lousy power supply, you would at least want a filter cap (or two) at the power input.
