On your yellow fluke meter, turn the dial to just to the right of 12 o'clock to the Greek letter Omega, which kind of looks like a horseshoe. That's the resistance setting. Touch one probe (red or black, doesn't matter) to one lead of a resistor, and touch the other lead to the remaining lead of the resistor. Try not to also touch the metal parts with your fingers at the same time or it will probably throw your measurements off. Try measuring one resistor this way and report back. (I hope I am understanding your question...)
Thanks EBK! Thats what I did, ohms for resistance, but i just got frustrated at cant tell the colors. The white background method was alot easier.
The 1% tolerance resistors are definitely harder to read because of their blueish background color, and it is not always easy to tell which end is band #1. The 5% tolerance ones are beige in color, and have a distinctive final gold-colored band (For better noise performance, however, you'll want to stick to 1% metal film resistors, which are what came with your kit). In time, you'll probably become able to recognize the first two bands on sight, especially brown-black (10), yellow-violet (47), red-red (22), and orange-orange (33). There are some values you will see very often and more easily recognize later (1k, 10k, and 100k, for instance). I occasionally have trouble determining whether a band is red or orange, and I've had decades worth of experience looking at them.
The good news is that with 1% tolerance resistors, your multimeter reading should be very close to the nominal value of the resistor and allow you to identify it. (Are you getting a number on the screen when you try this? Just want to make sure your meter is working.)
For now, I hope you are able to, after some effort, identify your resistors, whether by sight or by instrument. If you run into difficulty, post a picture of a bunch of resistors laid out in a row, and we will help you identify them.
