Author Topic: dr boogie finished but no sound:(  (Read 1513 times)
zakk33
« on: July 13, 2017, 12:48:38 PM »
hi
i ve just finished my dr boogie pedal thanx to kingmafw:) but i have no sound.
so after checked the connexion i build an audio probe to follow the signal.
i start by touching the "ring" of the stereo jack and i have sond but when i touch the resistance after nothing :(
i tried to touch any component and i don't have the sound of my cd player but "poc" sound or nothing .
could you help me please ?
cheers
Re: dr boogie finished but no sound:(
« Reply #1 on: July 14, 2017, 03:49:05 AM »
You might want to get Aron to move this to the main "Building your own stompbox" area, since this may have little passing traffic.  But in any case, while you're there, check out the "Debugging" sticky thread at the top.  It really works.  Having said that, if you have audio at one end of a resistor and not at the other (assuming it's in the audio path), then you might want to check for dry solder joints.  BTW, your signal should be on the tip of the stereo input jack, not the ring.  You might want to check your jack and switch wiring as well.
