Author Topic: Help modding my CS9 chorus?  (Read 671 times)
acobberson
« on: July 27, 2017, 12:50:44 PM »
Hey all!
Recently the flip-flop circuit on my Ibanez CS9 quit flipping and flopping. While I was in there I figured I would mod it for true bypass. After looking at the schematic I figured it would be simple enough. Here is what I did.
1. removed Q105 and jumpered Drain to Source.
2. wired in a 3pdt switch, just like I have done 1,000 times. Input jack to switch, switch to circuit input, circuit output to switch, switch to output jack... that's when it hit me... Stereo output.
So then I simply sent circuit output 2 directly to the second output jack. If the signal is bypassing the circuit anyway (in bypass mode) this shouldn't effect anything, right? Then when the signal hits the circuit, both outputs are being sent to their respective output jack.
For now I'm just running it mono, but it ain't working.
Any ideas as to what the problem could be? Should I have left Q105 in the circuit and THEN jumpered Drain to Source?
Here is the schematic. And a crude drawing of my own signal wiring.
« Last Edit: July 27, 2017, 01:48:11 PM by acobberson »
