Author Topic: Need some help to repair an MIJ HM-2  (Read 2056 times)
sdk
« on: August 29, 2017, 02:39:55 AM »
Hello,
I've got an MIJ Boss HM-2 but it doesn't work properly. When engaged, the sound is fuzzy and the LED is very dim. In bypass mode I get no sound at all. I've jumpered the wires 4 and 5 to accept the PSA adapters. I'm using a 9v 500ma one.
Inside everything looks fine, so I have no idea what can be wrong with it.
Thanks in advance for any help.
Schematic:
Re: Need some help to repair an MIJ HM-2
« Reply #1 on: August 29, 2017, 07:58:12 AM »
Does it function properly with a battery?
sdk
« Reply #2 on: August 29, 2017, 09:56:09 AM »
I bought it on Ebay, it came without the battery jack.
« Reply #3 on: August 29, 2017, 12:30:38 PM »
You mean no battery snap of the sort that normally fits under the foot treadle?
Govmnt_Lacky
« Reply #4 on: August 29, 2017, 02:37:41 PM »
Agreed! Spend the $0.50 and add a battery snap. Retest. If still fuzzy with dim LED then measure voltage at Pin 8 of any of the IC chips. See if you are getting ~8-9VDC. If not, then look at D2 and C2 to start.
Good Luck  ;)
for an amount of ‘up to and including my life.’
sdk
« Reply #5 on: August 29, 2017, 03:27:00 PM »
Yup!
Good Luck  ;)
I'll solder a new one in but first on sunday, I'm not home now.
« Reply #6 on: August 29, 2017, 04:03:27 PM »
Agreed.  There are so many tales here from those who posted that "the effect" works with a battery but not with an adaptor.
Keep in mind the HM-2 is a rather oldish pedal. The contacts in the external power jack might be corroded and very high resistance.  I've had plenty of older jacks that didn't behave well.
sdk
« Reply #7 on: September 02, 2017, 07:28:45 PM »
Probably a dumb question, but where should I solder the battery wires in? Negative goes to number 5 on the board but I'm not sure where the positive one has to be.
« Last Edit: September 02, 2017, 07:33:55 PM by sdk »
« Reply #8 on: September 02, 2017, 09:01:50 PM »
There's a pretty good chance that by now someone has posted a gutshot that shows all the wires in full color, and where they go.
sdk
« Reply #9 on: September 03, 2017, 04:09:59 AM »
On both battery and power supply I get 9vdc on the pin 8 of the IC's but when powered with a battery the LED doesn't light up and with the power supply same thing as before.
« Last Edit: September 03, 2017, 04:11:31 AM by sdk »
anotherjim
« Reply #10 on: September 04, 2017, 02:22:50 PM »
Reference the schematic, and find all those test voltages shown in rectangles. That should be a good trouble shooting start.
Battery ground should be on the ring contact of the instrument input jack socket. It won't connect to the circuit unless a plug is in the socket. Check you have 0v on pin4 of the IC's.
Croeso i Diystompboxes.
If they didn't hear you then you didn't say it.
sdk
« Reply #11 on: September 09, 2017, 04:43:09 AM »
Voltages I get on the ICs:
