ON-ON-ON DP3T toggles?
Started by ExpAnonColin, November 06, 2003, 11:52:34 PM
ExpAnonColin
I really want some... They're like 15 dollars on mouser, however.  I want ON-ON-ON DP3T or SP3T toggles, not rotarys, toggles, not slides, toggles... anyone have a cheaper place?
-Colin
Ansil
i wish i did keep me informed if you find one, my guitar uses that switch, to work properly
ExpAnonColin
Quote from: Ansili wish i did keep me informed if you find one, my guitar uses that switch, to work properly
There are some on mouser... do a search for DP3T ON-ON-ON.
-Colin
dp
dp
ExpAnonColin
Quote from: dpcheck out www.stewmac.com
Thanks, they have on-on-on's there, but they don't say how many pulls and throws they have :?
-Colin
Hal
Radio Shack has on-on-on's...I think they're DPDT, though...they have a weird pinout.
I think you can use a DPDT as a SP3T if you wire it right (not sure)
its something like this...
Pos2:
the other positions are just as an on-on DPDT would be....
can you do something with that ? btw the radio shack swtich is about $5 I think.
ExpAnonColin
Quote from: HalRadio Shack has on-on-on's...I think they're DPDT, though...they have a weird pinout.
A DP3T would hae a weird pinout, yes, because there would be 3 rows of throws and only 1 row of pulls, so you can't put it in the middle at all...
Either I don't understand you diagram or it doesnt work...  :(
-Colin
Peter Snowberg
I've never seen an on-on-on that wasn't DPDT.
To expand on Hal's diagram- If you label the six terminals as two commons ("C"), and two throw positions each (labeled "A" and "B"), this is what you'll see.
Overview:
A A
C C
B B
Below: the black labels below are not connected while the colors are.
Position 1:
A A
C C
B B
Position 2:
A A
C C
B B
Position 3:
A A
C C
B B
To make a DPDT on-on-on into a SP3T, use the blue C above as the common; wire a jumper from the blue A to the red C; and the three throws are (in order) red A, red B, and blue B.
Caution: I might have flipped the poles in position 2, check with a meter to be sure. :)
-Peter
Eschew paradigm obfuscation
ExpAnonColin
Quote from: Peter SnowbergI've never seen an on-on-on that wasn't DPDT.
Overview:
A A
C C
B B
Position 1:
A A
C C
B B
Position 2:
A A
C C
B B
Position 3:
A A
C C
B B
-Peter
Whoops, I was thinking of an on-off-on... that was the problem.  A DPDT on-on-on might work, but I'm thinking I'll need a DP3T (yes,they exist, do a mouser search)
-Colin
