ADAU1701 stereo chorus
Started by Vlad Koen, March 20, 2018, 04:01:06 PM
Vlad Koen
ADAU1701 dsp chip stereo chorus - flanger - exciter
Made in tee box.
soundcheck on
https://soundcloud.com/sun_sequence/tee-chorus-diy-box-test
Digital Larry
That's pretty cool.  I wasn't too familiar with the ADAU1701, mostly having the Spin FV wrapped around my axle.  But this looks like it could be good for some things that are difficult on the Spin, especially opening up a more flexible set of input controls (4 pots, switches) and possibly getting better SNR.  Price wise it seems close to the FV-1.  Did you get a developer board to prototype this or are you just naturally brilliant?
Also wondering about the assembly, did you do it by hand?
Digital Larry
+1 Agree, very cool.
My only "oh what a pity!" moment was the limited on-chip RAM. Otherwise that seems like a great chip.
I'm also not clear why these DSP chips tend to run from an external EEPROM rather than on-chip Flash memory like most uPs these days. Is there a technical reason for that? On-chip flash would be easier and save another chip...but these are questions for AD, not you.
Anyway, nice work.
Tom
free electron
Quote from: ElectricDruid on March 21, 2018, 02:53:02 PM
Tom
Flash read/write operations are often too slow to run dsp applications. Firmware is loaded into RAM and run from there. DSPs are usually accompanied by another "houskeeping" MCU, which may store the firmware and load it in to DSPs RAM at startup. Or just use an SPI/I2C bus and an external memory.
Here is an open source programmer for the AD's Sigma series of DSPs:
https://github.com/freeDSP/freeUSBi
Vlad Koen
Hi !
It is nice to see all replays on my box.
I bought a processor in an online store, and a circuit board to it.
Vlad Koen
Structure of chorus and flanger in Sigma studio:
Digital Larry
Quote from: Vlad Koen on March 22, 2018, 02:22:08 PM
Do you mind tell me where you got those items?  I couldn't find anything comparable through a casual web search.
Digital Larry
Vlad Koen
I bought this set on very special place, on russian website:
https://www.chipdip.ru/product/dsp-rdc2-0027v2
this is the electrical circuit:
https://static.chipdip.ru/lib/868/DOC002868482.pdf
But the same thing there is, and with sigmastudio USBi interface:
https://www.minidsp.com/products/minidspkits/2-x-in-4-x-out
But better to start with ADAU1452, because memory (to make simple reverb) is 40kB.
Jast now I looking for A DAY 1466, latest simple sigmastudio processor with 96 kB memory.
Unfortunately, AD don't sell it in 10-pic set.  Only do it at 1000 ))
Vlad Koen
Now I have got improvement for my stombox.
First of all, it have been moved to steel box; plus  add input compressor , distortion, presens filter at 2500 hz , and headphones  amplifiers .
Now it is complete sound box for home guitar repetition.
I think about to add delay on external pt2399.
Vlad Koen
Adau1701 low sampling rate.
Today I was able to change the adau1701 to a low clock speed, about 11 kHz sampling.
To do this, I changed the quartz from 12 MHz to 3.5 MHz, and increased the resistance of the resistor in the ADC circuit (see PDF) from 18k to 100k.
After that, the delay line became about 200 ms.
At the AD forum it is said that it is impossible to change the ADAU1701 lower than 44kHz.
Digital Larry
Quote from: Vlad Koen on April 09, 2018, 09:57:46 AM
Sometimes when vendors say something is "impossible" it simply means they haven't tested it, can't guarantee it, or for whatever reason don't want to support people trying to do things that way.  In this particular case I have no idea, but I can imagine people running at really low sampling rates and then complaining about how crappy it sounds.  Nyquist who?
Digital Larry
